Hi
I have few flexunit test cases . When I am running those testcases from Flashbuilder FlexUnit plugin I am able to run all the testcases and when I run Build file to run those testcases , build file is launching my testrunner swf file and it is throwing follwoing runtime error in flash player
VerifyError: Error #1014: Class flash.events::NativeWindowBoundsEvent could not be found.
at flash.display::MovieClip/nextFrame()
at mx.managers::SystemManager/deferredNextFrame()
at mx.managers::SystemManager/preloader_preloaderDocFrameReadyHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.preloaders::Preloader/timerHandler()
at flash.utils::Timer/_timerDispatch()
at flash.utils::Timer/tick()
here is the Build Console log
[taskdef] Could not load definitions from resource flexTasks.tasks. It could not be found.
test:
[mxmlc] C:\Users\user\Documents\workspace\project\bin-debug\projectTestRunner .swf (1626331 bytes)
[flexunit] Validating task attributes ...
[flexunit] Generating default values ...
[flexunit] Using the following settings for the test run:
[flexunit] FLEX_HOME: [C:\Program Files\Adobe\Adobe Flash Builder for Force.com\sdks\4.5.1.21328]
[flexunit] haltonfailure: [false]
[flexunit] headless: [false]
[flexunit] display: [99]
[flexunit] localTrusted: [true]
[flexunit] player: [flash]
[flexunit] command: [C:\Program Files\Adobe\Adobe Flash Builder for Force.com\sdks\4.5.1.21328\runtimes\player\10.2\win\FlashPlayerDebugg er.exe]
[flexunit] port: [1024]
[flexunit] swf: [C:\Users\user\Documents\workspace\project\bin-debug\projectTestRunne r.swf]
[flexunit] timeout: [60000ms]
[flexunit] toDir: [C:\Users\user\Documents\workspace\project\report]
[flexunit] Setting up server process ...
[flexunit] Starting server ...
[flexunit] Opening server socket on port [1024].
[flexunit] Waiting for client connection ...
[flexunit] Entry [C:\Users\user\Documents\workspace\project\bin-debug] already available in local trust file at [C:\Users\user\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust\flexUnit.cfg].
[flexunit] Executing 'C:\Program Files\Adobe\Adobe Flash Builder for Force.com\sdks\4.5.1.21328\runtimes\player\10.2\win\FlashPlayerDebugg er.exe' with arguments:
[flexunit] 'C:\Users\user\Documents\workspace\project\bin-debug\projectTestRunne r.swf'
[flexunit] The ' characters around the executable and arguments are
[flexunit] not part of the command.
[flexunit]
[flexunit] Stopping server ...
[flexunit] End of test data reached, sending acknowledgement to player ...
[flexunit] Closing client connection ...
[flexunit] Closing server on port [1024] ...
BUILD FAILED
C:\Users\user\Documents\workspace\project\build\build.xml:33: The following error occurred while executing this line:
C:\Users\user\Documents\workspace\project\build\build.xml:175: java.util.concurrent.ExecutionException: Socket timeout waiting for flexunit report
Many thanks for In advance for your help ..
