I shoot digital product and food photography using a mac powerbook. I've been using a LaCie CRT (yes, I said CRT) monitor for fine tuning my photos. It has finally started acting up so I'm ready for a new monitor. Can anyone recommend a dependable monitor that has color, brightness and contrast controls for use with establishing color managed profiles using eye1 macbeth (now that company is called something else which I can not remember at the moment). Obviously it needs to be accurate when it comes to color, brightness and contrast as well.
I ended up using my laptop screen this past shoot cause I had no other choice - but it made me really nervous.....
thanks -
First of all, my sincere condolences for your loss. Losing your last high-end CRT is a traumatic loss. I'm still hanging on to two (2) of them! (Knock on wood!)
Highly recommended monitors:
The NEC 2690 and 2490.
You want to use the SpectraView II software to conduct all the work internally and use GammaComp and ColorComp.
____________
Wo Tai Lao Le
我太老了
marshmallow88 wrote:
Trying not to spend extra money - is the old Gretag Macbeth profiling
software/system not good with the recommended monitors?
Do you want honest advice and recommendations or are you just looking for reassurance? ![]()
If the former, just see the above posts. If the latter, I wouldn't know what to tell you. ![]()
____________
Wo Tai Lao Le
我太老了
The instrument may be supported in SpectraView II depending on how old it is. But you want to drive the calibration and profile process on a SpectraView II using their software to take full control of the panel. You do not want to use the GretagMacbeth software to calibrate the SpectraView II system.
Andrew - thank you for the helpful information. The PA series is a little higher than I wanted to spend (when adding in the spectravision II) - what do you (and anyone else reading this) think about the it comes with the spectravision II and is only $600\ I do product and food photography for print (sell sheets)NEC MultiSync P221W-BK 22" Widescreen LCD Computer Display with Calibrator
Thanks for everybody's input. I ended up getting the NEC 241W-BK-SV. It was more than I wanted to spend but it does offer the whole solution (including the SV) and I know that when I'm under the gun, getting those images processed under a timeline, I'm going to want to be working with a dependable monitor/color management system.
