Can I Script the function of overlay creator panel?
Jun 8, 2011 4:00 AM
Can I control from script (with javascript) the function of overlay creator panel of ID CS5.5?
Where can I found documentation?
    Aug 3, 2011 4:36 AM   in reply to LeonardoAgosti
    Hi Leonardo, I have the same problem. Did you find an anwser?
    Thanks in advance, Paul :-)
    Aug 3, 2011 5:05 AM   in reply to LeonardoAgosti
    The level of scriptability is probably very limited because it's a Flash panel.
    That said, what are you trying to do?
    Harbs
    Aug 3, 2011 12:53 PM   in reply to Harbs.
    Hi Harbs,
    i’ve the same question. Im my case i want to set anchor frames from xml via script and assign a URL in the webview panel to the anchored frame.
    Thanks for your help!
    Best regards
    J. Puff
    Aug 8, 2011 3:40 AM   in reply to J.Puff
    I found a way to overcome this.
    Export the object as a snippet.
    Now you have an XML text file that represent the object.
    Open it in your code and replace the
    <KeyValuePair Key="Type" Value="Panorama"/>
    etc
    with the values that you wish to.
    Now import this snippet and you can actually script the overlay creator.
    Eli
    Aug 8, 2011 4:06 AM   in reply to Eli.Shklovsky
    Well, I found a better way:
    Just because all the data of the object is actually KEY/VALUE labels:
    We can simply do it like this:
    myObj = app.selection[0]
    myObj.insertLabel("Type","Panorama")
    myObj.insertLabel("AssetList","C:\\myFolder\\")
    myObj.insertLabel("InitialFOV","70")
    This is for panorama, we can do it for the rest of the overlay ojects like pan-zoom etc.
    Of course we should get the KEY/s for each object and immitate the code that stands behind the flash overlay creator panel
    Eli
