Basically I am trying to implement javascript or formcalc to perform the following function...
When you check the highcost_Yes check box the value in field charge1 changes to 10, with no check in the highcost_Yes field the value of charge1 should be 8.
I have the default value for the charge1 field set to 8 as well if that may be causing me issues.
check box highcost_Yes (values set to 1 or 0)
This is the javascript snippit I tried:
if (highcost_Yes ==1)
charge1 == 10
}else{
charge1 == 8
After some reaserch I tried this formcalc code:
if(highcost_Yes == 1)then
(charge1==10)
elseif (charge1==8)
endif
I have been learning javascript this term in school so while I understand the concept I am far from practicing it efficiently.
Can anyone tell me where I went wrong? Thanks!
Hi Corey;
If I read your post correctly, highcost_Yes is the name of the radio button field. A radio button (and any field) is an object, so you need to look at its properties and not the field itself:
if (highcost_Yes.rawValue ==1)
rawValue will contain the current state of the field.
You may also try posting in the LiveCycle Designer or LiveCycle Forms forums. There are a lot more JavaScript and FormCalc people on that list.
