Hi all,
Windows XP TCS 2.5 and Captivate 5.5
I'm working on a simple exercise in which the user fills some fields. The user then clicks a button and the advanced action checks that all the fields are filled correctly. Fields are associated with user variables.
I want to check the values the user inputs case insensitive, but I can't find an easy way to do this. For now, I use JavaScript to set the variables to lower case when the focus of the text field is lost. This works, but requires a lot of maintenance.
Am I missing something very simple? Is my solution the wrong approach? Can I use/create a widget to help me? I appreciate any feedback.
Greet,
Willam
If you have any experience with building Widgets then you could create a widget that will take your variable in Captivate and then use the "String Methods" in Flash to convert it to lower case. It shouldn't be too difficult to achieve with a widget and it would definitely be lower maintenence than using JavaScript.
/Michael
www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips & Tricks and much more..
Thanks for the feedback. I've never used Flash before, but I found a few tutorials on creating widgets. I'm going to give that a try as some of my colleages also want to create simple forms. They don't know JS so I think a widget will be worthwile.
Greet,
Willam
