Hello all,
I've been researching PC's hoping to make an investment in the most powerful PC I can afford without breaking the bank, and I need some opinions. From my research online it would appear that the best setup for video editing would include an Intel i7 processor and an nVidia GeForce GTX 590 graphics card.
The problem is that every computer I see that has this combo is significantly more expensive than other computers that have an Intel i7 and GeForce GTX 570. The best bang for my buck I found was from HP--it had an Intel i7 processor but only a GeForce GTX 550 graphics card.
My question to you all is this: how much of a difference do these graphic cards make in terms of actual speed and cutting down work time & rendering time in After Effects & Premiere Pro CS5/CS5.5? Is it worth the extra $300-$400 to get the GTX 590? Or would that only serve to knock off a miniscule few minutes off of rendering times/software performance? Furthermore, could I get away with fast speeds and rendering times with a GTX 550?
To give you an idea of what I'm using this software for: I work on HD DSLR wedding videos, occasionally with several layers of effects going on, and lots of transitions; I'll be working on videos ranging from a few minutes in length to upwards of 45 minutes in length.
I appreciate any input anyone has. Thank you in advance, and kindest regards!
-Michael
The 590 is OUT. It is a dual GPU and Adobe only uses one GPU. So it would be an utter waste of money. Your best bet is a single GPU like the 560 Ti/570 or 580. BFTB-wise (Bang-for-the-buck) the 560 Ti or 570 is probably your best bet. In AE you will not note any difference, in PR the difference is almost negligible.
Check out PPBM5 Benchmark
That's a very helpful link, thank you!
I think I'll go with the GTX 580 then. Your link mentioned how it was a very powerful card, but advised against buying it if the cost is too high or if the power supply isn't sufficient--I'm looking at an HP H8XT system that is actually decently priced and has an option for a good-enough power supply. Here are the specs:
| Operating system | SAVE $21 on Genuine Windows 7 Professional [64-bit] |
| Processor | Intel(R) Core(TM) i7-2600 quad-core processor with Turbo-Boost [up to 3.8GHz, 8MB cache] |
| Memory | 12GB DDR3-1333MHz SDRAM [3 DIMMs] |
| Hard drive | 2TB 7200 rpm SATA 3Gb/s hard drive |
| Secondary Hard Drive | 1TB 7200 rpm SATA 3Gb/s hard drive |
| Security software | SAVE $30 on Norton Internet Security(TM) 2011 - 15 month |
| Graphics card | 1.5GB NVIDIA GeForce GTX 580 [2 DVI, HDMI, VGA adpt] |
| Power Supply | 600W Power supply |
| Primary optical drive | SuperMulti DVD Burner |
| Networking | Integrated Ethernet port, No wireless LAN |
| Productivity ports | 15-in-1 memory card reader, 2 USB 2.0 (front), audio, 2 USB (top rear-facing) |
| Sound Card | Beats Audio (tm) -- integrated studio quality sound |
Beware of HP systems. In general they are unperpowered from a PSU point of view, they use custom PSU's that can not be exchanged for anything but HP, they use custom dimensions for the PSU so it is impossible to replace one yourself and they are anything but attractive from a BFTB point of view. They are very difficult to overclock if at all and are no more than mediocre performers.
The specs you gave show that this is an ill-configured system. An i7-2600 system should have 8 or 16 GB memory, not 12 GB. It should use 4 DIMM sockets, not 3. The PSU is underpowered for that video card. The primary disk is way too big for OS & programs and a complete waste of space. On a well tuned system 150 GB is more than enough. 2 TB is inappropriate. You miss the 3-rd and 4-th hard disk, that you really will appreciate to gain performance.
In short, these specs look like a waste of money.
Glad the site was helpful. I'm a bit of noob myself and just completed my first build. I went with a 570 with two fans in an open design. If you notice there was very little difference between the 570 and 580 although I was tempted to go with the 580 as well but had a significant price jump and there are better ways to improve my system with the savings.
Configuring a computer for video editing takes a lot of research. And even then you will just get general advice on your questions. So it's best to do some extra reseach instead of just relying on one website or reccomendation. Even the Adobe minimum reccomendations are insufficent.
Start with the FAQ list at the top.
I built my own with lots of info from here but be prepared for some frustration and plenty of research. However it should be very easy to build a much better computer than the HP list for less.
http://forums.adobe.com/thread/810750
http://forums.adobe.com/thread/662972
Check out some recent computer builds and you will see that you need more harddrives, more RAM, bigger PS, etc.
Then configure your own list and start a new thread.
*Whew* well that completely burst my bubble, haha! I've been doing constant research for the past week and thought I had finally come up with the best video editing desktop for my dollar.
On the bright side, thank you for pointing out my mistake before I went and spent all that money! :-)
Like I said, I've been trying to do so much research on finding the best PC I can afford for video editing in After Effects and Premiere Pro--can you or anyone else in here point me to a computer I can purchase that will fit the job? Or perhaps a link to another forum that can help me out? Thus far I have not been able to find a company that can build such a computer for around $2,000-$2,500, and I won't even begin to try and build one myself. I don't know a whole lot about pairing the right memory with the right number of sockets and hard drive or any of that.
In the meantime, I'll continue browsing through other forum topics in here to maybe help find what I'm looking for. Again, thank you very much for your helpful advice!
The most affordable solution is to build it yourself, but the drawback is that you have to be able to give your own support. If you want to buy, look at http://adkvideoediting.com/
They build very good machines within your budget and deliver top-notch support.
Your initial configuration looks a bit out of date (the i7-960, while very affordable is a rather old architecture). I suggest you contact Eric or Scott to help you out, but I would be more inclined towards an i7-2600K with 16 GB RAM or preferably an i7-970 with 24 GB memory. If you want to build it yourself, invest time to read about different configurations here on this forum. There is much to learn and digest, I think.
Thanks Harm and Mike for this posts.
Yes indeed a lot can be learnd.
(System Win7 64, 25GB Ram, I-7 960)
Im using an older Nvidia CX and want to upgrage to Geforce 570 or 580.
In my workflow i use 3 Displays. 2x flat TV (now connexion diplay port to HDMI) an 1x Panasonic 1760 for preview (connected via Blackmagic multibride SDI).
As is understood 570 or 580 have 3 ports out (2x DVI, 1x HDMI). I am not sure if they can be used at the same time simulanuesly.
My questions:
1.) can the 3 output-ports of 570/580 be used at the same time
2.) is it possible to use simultanusly 570/580 out-HDMI in connection with for example Blackmagic mini-converter (HDMI to SDI) to connect SDI (preview-monitor Panasonic 1760)
3.) where are mistaces in my thoughts
thanks for your help
klfi
