David Healy
How do I loop an Edge animation? How do I Duplicate Layers?
Aug 9, 2011 11:10 PM
Is there a setting that makes the exported animation loop?
How do I duplicate layers or element layers? What do you call them anyway?
How do I lock or unlock, view or hide all of the layers other that the one I have selected like I can in Illustrator?
Here is a sample: http://www.idugsf.com/_e_dheyes/DavidEyes_Edge01.html
where I want to duplicate the eye but can't find the control
    Community Member
    Aug 9, 2011 11:39 PM
    <script language="JavaScript">
        $(window).ready(function() {
            $.Edge.symbol.get($("#stage"))._getTimeline("Default Timeline").addObserver({ onComplete: function() {
                $.Edge.symbol.get($("#stage")).play("Default Timeline");
    </script>
    hope the next release have "ctrl+d"for duplicte layer
    Adobe Employee
    Aug 10, 2011 4:18 PM
    There is no way currently to duplicate an element.  We will be looking into this for future previews.
    Mark
    Community Member
    Aug 11, 2011 9:38 AM
    I haven't tried it, but couldn't you trace down the ID, copy it into a class, then add the class into that array?  Something along those lines?
    Community Member
    Aug 11, 2011 1:17 PM
    thanks for the first laugh of the day love the rolling eye!!
    don't forget the looping code problems that I had with the hidden characters.
    if it doesn't work look at the source code and see if there's any of them in there!!
    Community Member
    Aug 22, 2011 3:59 PM
    Minor mod (bodge?) to the javascript loop function to give a set number of loops:
         max_loop=4;
         count=0;
               count++;
                  if(count< max_loop) {
    </script>
    Adobe Employee
    Aug 22, 2011 4:22 PM
    "Duplicate Layers" is basically what I answered earlier in the thread.
    It's not in Preview 1, but will be added in future previews.
    Hope that helps!
    Mark
    Community Member
    Aug 22, 2011 4:27 PM
    No, learning to type is the answer ;-)
    fvrw,
    Community Member
    Aug 25, 2011 7:03 PM
    Hi....
    OK....cause I really don't know code.....
    per our attached code for looping, is this "Windows" relevant... will it work on a Mac and Windows?
    And where ould I insert this code in my source code?
    I am going to try to play this on a PC laptop....but since it is .html I assume it will work on either?
    Community Member
    Aug 26, 2011 10:00 AM
    And what about looping? So, you have to loop with code? You're kidding me! Looping is one of the most basic animation techniques and Adobe Edge doesn't have a simple way of doing that?
    Community Member
    Aug 26, 2011 10:27 AM
    @fvrw It goes in your html file just before the </head> tag, something like this:
    <!DOCTYPE html>
    <html>
    <head>
         <title>Untitled</title>
    <!--Adobe Edge Runtime-->
        <script type="text/javascript" src="edge_includes/jquery-1.4.2.min.js"></script>
        <script type="text/javascript" src="edge_includes/jquery.easing.1.3.js"></script>
        <script type="text/javascript" src="edge_includes/edge.0.1.1.min.js"></script>
        <script type="text/javascript" src="edge_includes/edge.symbol.0.1.1.min.js"></script>
        <script type="text/javascript" charset="utf-8" src="html5_test01_edge.js"></script>
        <link rel="stylesheet" href="html5_test01_edge.css"/>
    <!--Adobe Edge Runtime End-->
    <!--Adobe Edge Loop script -->
         max_loop=4;
         count=0;
                        count++;
    </script>
    <!--Adobe Edge Loop script End -->
    </head><body>
         <div id="stage" class="symbol_stage">
         </div>
    </body>
    </html>
    Hope this helps.
    Community Member
    Aug 26, 2011 11:34 AM
    @threebit
    I presume you are an advocate of the "no good deed goes umpunished" school of thought.
    Adobe Employee
    Aug 26, 2011 11:26 AM
    As we have said in a number of different messages, this is simply a first
    preview. There are a ton of things that you would expect to be in the
    product that are not there yet.  Rest assured that we are working on
    adding looping and a number of other critical features to future previews
    of Edge.
    Thanks for trying out Edge!
    Mark
    Community Member
    Aug 26, 2011 1:35 PM
    I look forward to the full release of Adobe Edge. For now I'm going to use Tumult Hype.
    Adobe Employee
    Aug 26, 2011 1:41 PM
    I would say to make sure you check out the previews as they're released.
    Mark
    fvrw,
    Community Member
    Aug 26, 2011 8:27 PM
    Thank You Adobe_blue.
    Let you know if it works.
    fvrw,
    Community Member
    Aug 26, 2011 8:36 PM
    This has been a good forum for getting feedback.  Looking forward to seeing how the final version of Edge will work. I like it so far, but still leaves a lot to be desired. For one- importing audio, and allowing for more than one track to be imported. Auto page turn affects and some other functions like shading gradients, and maybe even a little 3D effects thrown in for good measure. But I am sure you guys are on it.
    Thanks for the responses.
    Community Member
    Nov 28, 2011 3:37 AM
    It is said Adobe Edge supports hyperlink and loop animation in product explanations. I tried the code  above for loop in my html but it doesn't work. How could i get loop
    propperty in a basic location animation, exactly which code should i add to my html file?
    Community Member
    Nov 29, 2011 4:22 PM
    I think this should work to loop your animation: (in Preview 3)
    Create a trigger at the very end of your timeline, and add the following code to your custom function:
      // When this trigger is hit, restart the timeline by // calling play with a time offset of zero.  this.play( 0 );
    More here:
    http://blogs.adobe.com/adobeandjquery/2011/10/04/adobe-edge-preview-3- available/
    Community Member
    Nov 30, 2011 6:13 AM
    FOUND THE ANSWER!!!!!!!
    Add a code snippet to loop an animation
    New to Preview 3 is the addition of code snippets. These are little pieces of JavaScript code that can be added to your movie for common tasks such as looping. In this exercise you are going to do just that. When the movie finishes you want to loop back to the 5-second point on the Timeline. Here's how:
    1. Make sure the playhead is at the end of the Timeline.
    2. Scroll to the top of the Timeline panel and click the little icon that looks like a small scroll beside Actions. This icon is called the Open Timeline Actions icon.
    3. You will be prompted to add an event. Select the complete event from the pop-up menu (see Figure 20). If you don't see the pop-up menu, click the + button.
         Figure 20. You can choose from four Timeline events.
    1. The Default Timeline dialog box will now change to show you a number of snippets that can be added to the Timeline (see Figure 21).
    2. Select Go To and Play from the list. When you make this choice the code snippet shown in Figure 21 appears.
         Figure 21. Code snippets can be added to the Timeline and you can use your own values.
    1. Change the default time from 1000 (1 second) to 5000 (5 seconds). What you have just done is to write a snippet of code that will scoot the playhead back to the 5-second mark on the Timeline and start the animation playing from that point.
    2. Close the dialog box and test this project in a browser by pressing Command/Ctrl+Return.
    3. When finished, close the browser and save the file.
    Adobe Employee
    Nov 30, 2011 3:16 PM
    Handling the "complete" event is the best way to to loop if you indeed want to loop once the timeline is done with the animation.
    One step that is not necessary is step 1.  You don't have to have the playhead anywhere in particular to handle a timeline event.
    Mark
    From: Adobe Forums <forums@adobe.com<mailto:forums@adobe.com>>
    Reply-To: "jive-919121375-98qy-2-2ewcw@mail.forums.adobe.com<mailto:jive-919121375-98qy-2-2ewcw@mail.forums.adobe.com>" <jive-919121375-98qy-2-2ewcw@mail.forums.adobe.com<mailto:jive-919121375-98qy-2-2ewcw@mail.forums.adobe.com>>
    Date: Wed, 30 Nov 2011 05:13:45 -0800
    To: Mark Anders <anders@adobe.com<mailto:anders@adobe.com>>
    Subject: Re: How do I loop an Edge animation? How do I Duplicate Layers? How do I loop an Edge animation? How do I Duplicate Layers?
    created by ryganley<http://forums.adobe.com/people/ryganley> in Edge Preview - View the full discussion<http://forums.adobe.com/message/4054352#4054352
    Community Member
    Dec 1, 2011 1:23 AM
    Thank you all, it works
    Adobe Employee
    Dec 5, 2011 12:44 PM
    Hi David, I'm not sure what you're saying.  You say "I saw" but I'm not sure what you saw.
    Mark
    Reply-To: "jive-150047975-98qy-2-2f4f5@mail.forums.adobe.com<mailto:jive-150047975-98qy-2-2f4f5@mail.forums.adobe.com>" <jive-150047975-98qy-2-2f4f5@mail.forums.adobe.com<mailto:jive-150047975-98qy-2-2f4f5@mail.forums.adobe.com>>
    Date: Mon, 5 Dec 2011 11:36:54 -0800
    created by David Healy<http://forums.adobe.com/people/David+Healy> in Edge Preview - View the full discussion<http://forums.adobe.com/message/4064801#4064801
    Community Member
    Dec 13, 2011 10:55 AM
    How do I loop a single element? Say I have 3 elements with different timings and want them looped, what do I do?
    Adobe Employee
    Dec 13, 2011 11:38 AM
    Are talking about each object having an individual timeline, that you can loop independently?  Sort of like the equivalent of a Flash Movieclip?  If so, it's not in Edge yet.  We are working on it, though!
    Mark
    Community Member
    May 3, 2012 7:57 PM
    Not sure if this is what you're after or not, however, with the timeline placed at the end of the animation, I inserted a timeline action by clicking the "open timeline actions" button, then, inserted a "complete" function, with a "play" command, which is play the master timeline.
    Hope that helps. Cool app.
    s
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
