dwanegos
Cairngorm Module Library - RSLData error with Flex 4.1 & Parsley 2.4
Aug 12, 2011 4:09 AM
After upgrading a project from Parsley 2.3.2 to Parsley 2.4.0 I'm am experiencing the following error when compiling in Flex 4.1
1046: Type was not found or was not a compile-time constant: RSLData.
As part of the change I upgraded some of the Cairngorm librarys for Parsley 2.4 support but it appears that Module 0.17 is dependant on Flex 4.5? Is my assumption correct?
Here are a full list of the dependenies upgraded for reference:
  • com.adobe.cairngorm.module 0.17 (Upgraded from 0.15)
  • com.adobe.cairngorm.navigationParsley 1.7 (Upgraded from 1.3)
  • com.adobe.cairngorm.integrationParsley 0.17 (Upgraded from 0.15)
  • org.spicefactory.parsley-flex4 2.4.0 (Upgraded from 2.3.2)
  • org.spicefactory.spicelib-flex 2.4.0 (Upgraded from 2.3.2)
Additional dependencies which weren't changed:
  • com.adobe.cairngorm.task 1.10
  • com.adobe.cairngorm.validation 1.12
  • com.adobe.cairngorm.popup 1.13
  • com.adobe.cairngorm.popupParsley 1.13
    Feb 26, 2012 6:36 PM   in reply to dwanegos
    Did you ever find an answer to this?  I am running into the same issue with needing to upgrade parsley to 2.4.x, but with parts of application heavily relying on cairngorm module, upgrading it from module-0.11 to 0.17 seems to break compile!
    Mar 23, 2012 2:48 AM   in reply to dwanegos
    I also run in to this error? does anyone has a solution for this?
