SCEvan
Textbox Watermark
Aug 12, 2011 6:53 AM
Hi, I am trying to figure out how to make a textbox watermark appear in the empty text field when creating forms in LiveCycle but I can't seem to find the solution. If anyone knows how to do this it would be a huge help. Thanks!
    Aug 12, 2011 7:04 AM   in reply to SCEvan
    If you select the textfield and go to the Object > Field palette. Click the Patterns button and tick Allow Null, then type if the message that you want the textfield to show, when it is null.
    There is an example here that I am intending to finish at some stage: http://assure.ly/pZ5sOz. Click under the line and type a name.
    Also have a look at page 2 in this example (on the righ hand side): http://assure.ly/ewrLMo. This has script in the enter and exit events to change the appearance of the text.
    Hope that helps,
    Niall
    Aug 12, 2011 7:58 AM   in reply to SCEvan
    I was referring to LC Designer. See screenshot below:
    Hope that helps,
    Niall
    Aug 12, 2011 9:18 AM   in reply to SCEvan
    You can also achieve this using script. See the example here: http://assure.ly/gcXx03. This is scripting a null pattern for a dropdown, but you can take a same approach for a textfield.
    Niall
    Aug 12, 2011 10:10 AM   in reply to SCEvan
    Make sure you're using a Text Field object and not a plain Text object. Text Fields allow user input and have patterns; Text objects are for static (non-input) text display and do not have patterns associated with them.
    Aug 12, 2011 10:31 AM   in reply to SCEvan
    Can you post a screenshot of what your Designer window looks like, similar to what Niall posted?  It's strange that there's no Pattern button.  I'm using Designer 8 and I don't have that problem.
