Importing selected clips from a finalized DVD into PPCS4?
Aug 14, 2011 11:03 AM
I'm looking for the best way to extract small segments of video from a FINALIZED DVD (DVD-R) onto my computer for further editing.  I've tried with Premier Elements, Premier Pro CS4, Roxio, Norton and a few others.  Most all of them all import the complete file rather than giving you the option of selecting a specific piece of video.  For example, if I create a project consisting of 10 entertainers/acts in PP CS4 and take it to ENCORE to create a DVD disc, it is created as a single file.  Now, let's say I want to export/extract a specific entertainer/act.  WHAT I WANT TO DO IS VIEW/SEARCH THE DVD,  FIND THE ACT I'M LOOKING FOR AND CREATE AN 'IN' AND 'OUT' POINT TO EXTRACT/COPY/EXPORT THE WANTED ACT INSTEAD OF THE COMPLETE MOVIE/PROJECT.
Even when I use Premier Elements...I go to the GET MEDIA tab (from PC DVD drive) and the VIDEO IMPORTER opens and runs for a LONG TIME to open the 1-2 hour movie/file.  I can then select the VOB file and click GET MEDIA which is another long wait for it to copy.  The copied file is the complete VOB file and I only wanted one act (a 2-3 minute segment).
Again, what I want to do is, VIEW/SEARCH THE DVD,  FIND THE ACT I'M LOOKING FOR  AND CREATE AN 'IN' AND 'OUT' POINT TO EXTRACT/COPY/EXPORT THE WANTED  ACT INSTEAD OF THE COMPLETE MOVIE/PROJECT.
CAN ANYONE HELP ME WITH THIS?
Tom Mullica
tomasred@centurytel.net
    Aug 14, 2011 11:54 AM   in reply to Tom Mullica
    I don't think this is possible with any version of Premiere... setting in/out during capture is only possible with DV or HDV via Firewire from a tape camera
    For VOB from a DVD you must import the entire file (VOB's are maximum .99Gig per file, due to the DVD structure) and then once you have the file imported into Premiere, you may set in/out points for further use
    Read Bill Hunt on editing a VOB/MPG file http://forums.adobe.com/thread/464549?tstart=0
    Edit Vob http://premierepro.wikia.com/wiki/FAQ:How_do_I_import_VOB_files_/_edit _a_DVD%3F
    Aug 14, 2011 12:47 PM   in reply to Tom Mullica
    Here's what I'd do.
    http://www.videohelp.com/tools/XviD4PSP
    You'll notice on the borrom left, you can set In/Out points for the conversion.
    Aug 15, 2011 1:46 PM   in reply to Tom Mullica
    Tom,
    Yes, one can do this via hardware. There are two things to consider: the pass-through capabilities of the camera, and the possible In & Out connections. Instead of a camera, I use a Canopus A-D Bridge, but a camera with pass-through capabilities and the correct cables will work fine too.
    One thing that you will obviously not have is Device Control, but if you have the deck's remote in one hand, and the mouse in the other, by about the third time that you control both the deck and the Capture, you will have it down. Do not worry about a few extra Frames, as you can just Trim those out.
    Good luck,
    Hunt
    Aug 15, 2011 5:00 PM   in reply to Tom Mullica
    I would NOT use S-Video, but composite cables instead. I would also doubt that your camera has an S-Video Input.
    Good luck,
    Hunt
    Aug 16, 2011 1:17 AM   in reply to Tom Mullica
    where do I find
    the latest/best for windows7?
    Some things you just have to suss out on your own, Tom.  This one isn't that hard.
    Aug 18, 2011 8:54 AM   in reply to Tom Mullica
    Glad you got it working.
    Aug 23, 2011 8:35 AM   in reply to Tom Mullica
    The program will work as a stand alone, but you may not get the interoperability between PP and SB.
