Greetings!
I have created a simple 3-SCO 2004-manifest Multi-SCO package for upload to our LMS.
SCO1 - Pre-Test
SCO2 - Video
SCO3 - Post-Test
My problem is that no matter what I try, the playback freezes at the end of the first SCO and will not proceed to the second one.
Our LMS is Interactyx (which I gather is loosely based on Moodle).
On a lark, I also created a 1.2 manifest version, and it too failed to proceed from one SCO to the next.
In the "At End" options, I have tried forcing it to call the next SCO directly (link and by file name), and I have tried the "Stop" option, and I have tried the "Close" option and I have tried the "Continue" option.
Uploaded separately, each SCO works perfectly - I only have trouble w/ it going from one SCO to the next. I've called Adobe tech support and they've watched it do this via screen sharing and are working on it - but I hoped someone here might have a quick solution.
Does anyone have any tips/tricks/technomagic that will fix this for us?
I am having this exact problem with my MultiSCO. We have several modules set to close after playing. All of the SCOs open one after another perfectly, except that first one. The designer programmed a button on the last slide to open up the next movie in the sequence and it worked. Not as nicely as the other SCOs, but it did work. I know this is way to late to help you, but maybe it will help the next person!
Kelly
@KellyPhillipsNC
