flash player freeze all browsers: IE, firefox 5.0.1 and chrome 12: sometimes (3 session ok the 4th freeze), when I load a webpage with flash object the pc go in feeze and I only do to restart it, my old version 10.3.181.26 worked fine but when I instal the last 10.3.183.35 and reinstall the old the freeze come back always.
my pc is pentium 4 ht 3.2hz, 2 g ram, video card ati hd 3650 500mb with last driver 11.7, windows xp sp 3.
I disabled all hardware acceleration: by flash player, by browser and card graphics, but nothing!
I used to uninstall the adobe tool and clean the register by ccleaner, I used superantispyware and malwarebytes'antimalware for scan malware but all is cleaned.
I installed the last version of k-lite codec 7.6.
What I can do? how I can full delete the flash player in folder and register manualy?
C:\WINDOWS\system32\Macromed\Flash
FlashInstall.log
flashplayer.xpt
FlashUtil10v_Plugin.exe
NPSWF32.dll
=O====== M/10.3.183.5 2011-08-10+17-51-07.890 ========
0000 [I] 00000010 "C:\Documents and Settings\RAPTORSC\Impostazioni locali\Temp\install_flash_player_ax.exe" -dlm -install
0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/10.0 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0004 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10v.ocx
0005 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.exe
0006 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.dll
0007 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0008 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0009 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
=X====== M/10.3.183.5 2011-08-10+17-51-10.421 ========
I am confused by your post; the FlashInstall.log file shows the installation of the ActiveX, but in the installer folder you have only the plugin version.
Try using the uninstaller from http://kb2.adobe.com/cps/141/tn_14157.html
But in the log I see that you may have a problem with C:\WINDOWS\system32\FlashPlayerCPLApp.cpl - try deleting it manually before you run the uninstaller; use Unlocker if you cannot do it the normal way.
I manualy delete the file FlashPlayerCPLApp.cpl
after I use adobe uninstall
now the log is:
=O====== M/10.3.183.5 2011-08-16+07-56-27.265 ========
=X====== M/10.3.183.5 2011-08-16+07-56-28.750 ========
I test it, if doesn't work I will write in. thx
no, doesn't work, another freeze again.
I delete manualy the registry with this record? http://kb2.adobe.com/cps/191/tn_19166.html#main_DetermineVersion
list:
HKEY_CLASSES_ROOT\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}
HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
HKEY_CLASSES_ROOT\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}
HKEY_CLASSES_ROOT\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4}
HKEY_CLASSES_ROOT\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}
HKEY_CLASSES_ROOT\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B}
HKEY_CLASSES_ROOT\.spl HKEY_CLASSES_ROOT\.swf HKEY_CLASSES_ROOT\.mfp
HKEY_CLASSES_ROOT\.sol HKEY_CLASSES_ROOT\.sor
HKEY_CLASSES_ROOT\FlashFactory.FlashFactory
HKEY_CLASSES_ROOT\FlashFactory.FlashFactory.1
HKEY_CLASSES_ROOT\FlashProp.FlashProp
HKEY_CLASSES_ROOT\FlashProp.FlashProp.1
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.1
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.3
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.4
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.5
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.6
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.7
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.8
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.9
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.10
HKEY_CLASSES_ROOT\MacromediaFlashPaper.MacromediaFlashPaper
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/futuresplash
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.1
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.3
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.4
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.5
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.6
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.7
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.8
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.9
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.10
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
this is the uninstall log
=O====== M/10.3.183.5 2011-08-16+18-24-12.328 ========
0000 [I] 00000010 "C:\Documents and Settings\RAPTORSC\Desktop\uninstall_flash_player.exe" -force
0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 [W] 00001018
0005 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 [W] 00001019
0008 [W] 00001020
0009 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0010 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0011 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0012 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0013 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0014 [W] 00001021
0015 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0017 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 2
0018 [W] 00001048
0019 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0021 [W] 00001018
0022 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0023 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0024 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0025 [W] 00001019
0026 [W] 00001020
0027 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0028 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0029 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0030 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0031 [W] 00001021
0032 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0034 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 2
0035 [W] 00001048
0036 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0037 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0038 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0039 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
0040 [W] 00001036 Software\Opera Software/Last CommandLine 2
0041 [W] 00001036 Software\Opera Software/Last CommandLine 2
0042 [W] 00001036 Software\Opera Software/Plugin Path 2
0043 [W] 00001036 Software\Opera Software/Plugin Path 2
=X====== M/10.3.183.5 2011-08-16+18-24-15.890 ========
