There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Aug 18, 2011 Aug 18, 2011
my computer have acrobat reader 10.1.0 and have acrobat standard 7.0
when i use ie and view report (pdf) from browser . it shown error
"There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)"
General troubleshooting , Windows
336.6K
correct answers 2 Correct answers
Community Beginner , Jan 24, 2012 Jan 24, 2012
Thanks, ,Iliya9999 , that worked!
Much appreciated
Deleted User
OK, I got it to work. First I opened Adobe Acrobat 7.0 Professional. Then I followd MicheleDiaz's instructions. That eliminated the ERROR 0:104, but then I got the "Failed to Initialize" error. I downloaded Reader X from: http://get.adobe.com/de/reader/enterprise/  The instructions are in German, but of course it's obvious, and THAT worked!
Finally. What a pain.
Deinstall Adobe Reader and repair the installation of Adobe Acrobat.
Sep 01, 2011 Sep 01, 2011
I get the same error message.  I'm able to open pdf's that are saved to my hard drive, but not directly from the internet.  I've uninstalled and reinstalled many times.  I've also tried to do a "repair", but nothing has seemed to work.  Thanks...
Guest
Sep 07, 2011 Sep 07, 2011
I have some colleagues that suffers from the same problem...
Any suggestions to what is wrong. I tried to open a pdf in Internet Explorer locally stored on the computer, and that works fine?!? So it seems that something is only going wrong when opening a pdf directly from a link?!?
/Termo
Nov 10, 2011 Nov 10, 2011
Hello,
Some of our users have experienced the same issue and we've found a solution : You need to go in the preferences of your Acrobat X Reader, go to the "General" settings, and uncheck "Activate the protected mode at startup" (not sure the translation is correct I don't use a US version).
After that, it will work fine... but your Reader X won't anymore be protected against PDF containing malicious code.
If someone has a better solution (one that would let the protection activated) I'm interested.
NB : This issue is only reproduced on a few of our computers, and our IT service can't reproduce it, so it's most likely an incompatibility with something special on the few PC impacted. But we don't know what...
Nov 14, 2011 Nov 14, 2011
This worked and fixed the problem.
Dec 05, 2011 Dec 05, 2011
Simple, this error occures when you have two versions of Adobe Reader. Delete one of them and your problem should be solved at once.
Guest
Jan 13, 2012 Jan 13, 2012
Here's what worked for me with Reader 10.2:
     1) uninstall Reader
     2) disable virus protection;
     3) install Reader;
     4) enable virus protection
Jan 17, 2012 Jan 17, 2012
I have the same problem after Adobe X reader was installed on a server that already has Acrobat 7 Pro installed.  Abobe X reader was uninstalled and an update to Acrobat 7 Pro was installed.  The same error occurs.  Any ideas?
Guest
I have the same problem: Acrobat Pro 7 resides on the computer and I can't install Reader X because of the error:
"There is a problem with Adobe Acrobat/Reader. If it is running, please exit and try again. (0:104)"
As nobody seems to be able to make this work, I guess I'll assume I must first uninstall Acrobat Pro 7. Depends on how bad you need Pro 7 and how bad you need Reader X, I suppose.
MicheleDiaz, did you ever get it to work???
Ditto here, I tried re-installing Adobe Reader but that didn't work either, and it appears in my add on, so, I'll keep checking her to see if someone knows an answer.
Guest
MicheleDiaz, who had the same problem, replied to me. She said:
"To resolve my issue I had to disable the "Disable PDF in Browser" option.
This is located in Adobe Preferences (Edit, Preferences, Internet). With
that option off Acrobat opens the PDF."
I can't try it until I get home. If you can try it sooner, let me know.
Much appreciated
Feb 06, 2012 Feb 06, 2012
Resolved issue. Disabled 'Open PDF in Browser' option in Adobe Acrobat 7 Pro. Enable or disable same option in Acrobat Reader 10 depending on preference. Thanks for the help.
Dec 16, 2021 Dec 16, 2021
I went to Edit>Preferences>Internet, I onky have the following three options. all checked:
Display in Read Mode by default
Allow fast web view
Allow speculative downloading in the background
Where can I find the 'Open PDF in Browser'
Marco
Guest
Oct 08, 2012 Oct 08, 2012
Thanks Iliya9999
Your solution going into the Internet preferences worked for me too 🙂
Dec 08, 2015 Dec 08, 2015
This Solution worked for me... Many thanks to 9999
Guest
I totally agree. When something like this happens I spent hours of productive time fooling around trying to fix it! On the upside, it is free software, so I’m thankful to have it because it does the job when its working right.
Feb 07, 2012 Feb 07, 2012
Resolved 0:104 problem in Adobe Acrobat Standard 7.1.0. Unticked "Display PDF in browser" option as above and now displays PDFs in Explorer 8. Thanks very much for your help.
Jan 09, 2013 Jan 09, 2013
Guess this is a sameohsameoh. Had problem also; came here, did the UNcheck Display PDF in Browser and error goeth away...hooray. CS6 Acrobat BTW. My thanks also since that is quite a productivity inhibiting error.
Feb 15, 2013 Feb 15, 2013
I have tried multiple things, changing security settings, associating Reader instead of Adobe Acrobat 7, etc... finally found an answer on the Adobe site. Unfortunately its hidden and took me an hour to find so I thought I'd share because it finally allowed me to view PDFS from links on-line. The source is: http://helpx.adobe.com/acrobat/using/display-pdf-browser-acrobat-xi.html.
Open Internet Explorer, and choose Tools > Manage Add-ons.
  Under Add-on Types, select Toolbars And Extensions.
  In the Show menu, select All Add-ons.
  Select All Add-ons from the Show menu in the Manage Add-ons dialog box.
  In the list of add-ons, select Adobe PDF Reader.
     Note:  If you do not see the Adobe PDF Reader add-on, try the other options on the menu. For example, on some systems, the add-on appears when you select Run Without Permission.
    Click the Enable or Disable button (it toggles depending on the status of the selected add-on):
Enable sets the Adobe PDF Reader add-on to open PDFs in the browser.
Disable turns off the add-on so it does not open PDFs in the browser.
GOOD LUCK!!
Dec 01, 2014 Dec 01, 2014
Thanks!!!! I did what you say and it worked!!!
