I'm using the fp11 beta to stream h.264 video live between two machines. I'm also recording this live interaction. However, it appears as though FMS does not understand how to save the h.264 video? My set for the netstream looks like:
_netStream = new NetStream(_netConnection);
_netStream.client = customClient;
var h264Settings:H264VideoStreamSettings = new H264VideoStreamSettings();
h264Settings.setProfileLevel(H264Profile.BASELINE, H264Level.LEVEL_2);
_netStream.videoStreamSettings = h264Settings;
The resulting video has an audio stream, but no video stream. Is there some specific profile required for FMS to understand how to store h.264? Or, is this simply a feature that is yet to be implemented?
Ben
Thanks for trying FMS and H264 streaming.
Are you not able to save the file or not able to stream at all ?
You need to use netstream.record() API to initiate the recording on the server from the client , and alternatively use stream.record() to inititate the recording on the server side.
H264 is supported on FMS and it can be both streamed and recorded. Use mp4 / f4v file format (giving the prefix and the extension for streaming and recording), to use the H264 content.
Hope the information help
...Copy link to clipboard
Hope the information helps. Thank you !
Thank you for the quick reply!
I did not think to check the publish or play documentation - indeed, setting publish("mp4:stream.mp4", "record") does the trick!
Really excited about 264 encoding. Thanks again!
Now that I've got that working, another issue I've come across - the way speex is saved in mp4/f4v format using fp11 seems to be very different from the speex that was used previously. Here's the ffmpeg output from a spark-encoded .flv file:
Metadata:
duration : 297
videocodecid : 2
audiocodecid : 11
canSeekToEnd : false
createdby : FMS 4.0
creationdate : Thu Aug 18 22:13:01 2011
Duration: 00:04:56.76, start: 0.000000, bitrate: N/A
Stream #0.0: Video: flv, yuv420p, 320x240, 1k tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: libspeex, 16000 Hz, 1 channels, s16
Edit - formatting
I should be clear - this is probably not your issue. Looks like 'spex' is the fourCC code for libspeex. My issues are probably not FMS-related. Thanks!
I have the same issue I discussed in this thread: http://forums.adobe.com/thread/921502 Make sure you vote for the bug I submitted down toward the bottom of the thread.
hi,
I use FMLE to publish h264 video to FMS , my server side code (main.asc):
application.onPublish = function (client, stream)
var streamName = stream.name ;
trace("onPublish stream: "+ streamName);
stream = Stream.get("mp4:"+ streamName +".f4v");
if(stream){
stream.record("append");
stream.play(streamName);
I can save the H264 stream on the server,but less than 3 minites,the storage stops,How did this happen? please help me ! thank you !
maria
I am creating audio-Video chat application, I'm using the FP11 to stream h.264 video and Speex for audio.
I'm also recording for this live stream for future use. below is the code
_netStream.publish("mp4:record.f4v","record");
netStream.addEventListener(NetStatusEvent.NET_STATUS, streamNetStatHandler);
It is working fine when publishing and receiving live stream.
Issue is that :
file is recorded with f4v format at desired folder and file size also dispalyed, but not played in any media player.
Then I converted it into mp4 by using Adobe F4V Post Processor
then video is played but audio is totally missing.
Plz reply.
