Locked
FileReference.cancel
Guru ,
Aug 19, 2011 Aug 19, 2011
The docs are confusing me a bit.  They say, "Calling this method does not dispatch the cancel event; that event is dispatched only when the user cancels the operation by dismissing the file upload or download dialog box."  Is the cancel event supposed to fire if you call fileref.cancel() after you've called fileref.upload()?  If it isn't, then what's a file upload dialog box?
Development
2.1K
The Method, Cancel, is what you use to cancel an upload or download. The Event, Cancel, is what is sent when the user clicks on Cancel in an upload or download dialog.
So, if you are downloading something already, and for some reason you need to cancel the download, you would use the Method. If your user clicks on something to do an upload or download, but then changes their mind, and clicks the Cancel button in the dialog, you can detect that event and maybe present an appropriate message.
This all relates more to desktop browser work, I don't know if you would get involed in this with mobile apps.
Guru ,
The only dialog I picture in my head during the process is the file browse dialog, which makes sense if that fires when you hit Cancel in that.  I don't think I've seen modal Upload / Download dialog box before.
"If your user clicks on something to do an upload or download, but then changes their mind, and clicks the Cancel button in the dialog, you can detect that event and maybe present an appropriate message."  What dialog???
Try this script in the timeline of a new FLA:
import flash.display.Sprite;
import flash.events.*;
import flash.net.FileReference;
import flash.net.URLRequest;
var downloadURL:URLRequest;
var fileName:String = "SomeFile.pdf";
var file:FileReference;
FileReference_event_cancel();
function FileReference_event_cancel() {
downloadURL = new URLRequest();
downloadURL.url = "http://www.[yourDomain].com/SomeFile.pdf";
file = new FileReference();
file.addEventListener(Event.CANCEL, cancelHandler);
file.download(downloadURL, fileName);
function cancelHandler(event:Event):void {
trace("cancelHandler: " + event);
Do a Test Movie. What appears? Does it look something like a dialog box? When you click Cancel, does something trace?
Guru ,
So this is my situation - a user is in the middle of an upload (fileref.upload()) and hits my cancel button which calls fileref.cancel() on that file.  Well that cancel operation is blocking the UI from updating so there's a 3-4 second pause where you're thinking, 'huh, what's happening'.  What I want to do is present a message like 'cancelling' then remove that message when it's finished.  You see my problem in that calling cancel() doesn't fire the cancel event, but the docs are eluding to that it should if it's 'dismissing the file upload'.  What I don't understand is that's what I'm doing - and since I don't recall a modal upload dialog box I don't see when this event would ever fire..
Guru ,
Ahh so it's talking about BEFORE the operation is executing.  I'm thinking during here
The Event version of Cancel would only happen before the transfer. The Method version of Cancel would only be called after the transfer has started. It does make it slightly confusing when the class has two things called exactly the same thing.
Guru ,
Indeed it does. If it wasn't locking up the UI then I wouldn't even care, but now I need to know when the cancel operation is finished.  Back to the drawing board
Mentor ,
Since cancelling seems to be synchronous, wouldn't this work:
pseudo function
show "canceling" message
call cancel()
remove "canceling" message
Yes, what Joe said. The Method Canel isn't an event that has to work its way through the system, to sometime later actually do something. It's immediate.
Guru ,
Sadly it doesn't work like that either. The method I call after calling
cancel() is called immediately even though it's not done cancelling. Watch
this video and keep the below code in mind [
http://www.youtube.com/watch?v=ZKX5VMPF2tM - sorry that's its sideways].
The notify method alpha tweens in, and doesn't happen before the cancel()
like it should - I'm guessing due to the tween which is being blocked by
cancel() - but the upload view is tweening out before the notify message is
showing, even though its after the cancel() call and it's also tweening. I
don't get it
private function cancelVideoUpload(e:UploadVideoViewEvent):void{
if(uploadVideoView.isUploading){
notify('Please wait while your upload cancels...');
videoDataFile.cancel();
clearUploadView();
} else {
clearUploadView();
private function clearUploadView():void{
TweenLite.to(uploadVideoView.uploadContainer, .5,
{y:-(uploadVideoView.height), ease:Expo.easeOut,
onComplete:removeUploadVideoView});
private function removeUploadVideoView():void{
_desktube.removeChild(uploadVideoView);
uploadVideoView = null;
Here, this helps:
http://xfiles.funnygarbage.com/~colinholgate/video/cancelvid.mov
I think there's something slow about your notify routine. The canceling seems to take place correctly.
By the way, do you get the same results with AIR 2.7 instead of AIR 3?
Guru ,
Thanks for flippin that!  Here's the notify method, and here's the notification class http://dl.dropbox.com/u/1742552/Notification.as.  It seems like that's happening after because of the Tween - but what I don't get is why the uploadContainer is able to tween out but not remove itself before the no that happens
public function notify(str:String):void{
notification.width = stage.stageWidth / 2 > 400 ? 400 : stage.stageWidth / 2;
notification.field.text = str;
notification.redraw();
notification.x = int((stage.stageWidth / 2) - (notification.width / 2));
notification.y = int(stage.stageHeight - (notification.height / 2) - 100);
notification.alpha = 0;
_desktube.addChild(notification);
TweenLite.to(notification, 1, {alpha:1, ease:Expo.easeOut, onComplete:notificationOut});
I haven't tried this yet on the 2.7 SDK, but I will.
There are cases wher eFlash can leave junk on the screen. Maybe the upload thing was remvoed, but just has some dirt on the screen. Try putting a message into a visible textfield, so you can see at what moment the removechild happens.
It could be an AIR 3 graphical issue.
Guru ,
I added a 1 second delay to the cancel() call and it's working smooth now.
Not the cleanest thing in the world but it'll do!
