Indesign CS5 | Create layers and Distribute automatically. [script]
Aug 18, 2011 9:17 AM
Hi guys,
Is there some script to Indesign CS5 that create layers automatically and distribute text, images and objects to them?
Ex: I have one layer with many images and i would like to distribute them to another layers automatically.
Best regards,
JNSaraiva
    Aug 18, 2011 9:45 AM   in reply to JNSaraiva
    Below code creates a new layer named "ImageLayer" and move all images to that layer and add "TextLayer" to move text frames.
    pictureLayer = app.activeDocument.layers.add ({name: "ImageLayer"});
    textLayer= app.activeDocument.layers.add ({name: "TextLayer"});
    app.activeDocument.rectangles.everyItem().itemLayer = pictureLayer;
    app.activeDocument.textFrames.everyItem().itemLayer = textLayer;
    Mac
    Aug 18, 2011 10:18 AM   in reply to JNSaraiva
    Hope my perception would be wrong, I don’t think you run this script fragment otherwise I am not understanding what your requirement is sorry…
    Mac
    Aug 18, 2011 1:55 PM   in reply to JNSaraiva
    That's what the script above will do. Try it.
    Aug 19, 2011 6:15 AM   in reply to JNSaraiva
    Thats because the syntax is Adobe's ExtendScript and not AppleScript… C&P into ExtendScript Toolkit… This editing/debugging app can be found in your utilities folder…
    Aug 19, 2011 8:51 AM   in reply to JNSaraiva
    I didn't get so far as your script request… just noticed the problem… It does save some confusion/presumption if you state your OS and preferred scripting language if you have one…
    Aug 19, 2011 11:03 AM   in reply to JNSaraiva
    The fact that you had pasted into Apple Script Editor told me you were on a mac at least… It just helps other users help you, if they know these things. In ID versioning is pretty important too… I don't have 5.5 took a dammed eternity to get to 5… but if you are happy to use ExtendScript then there are many more helpers at hand… by far the most popular language in this forum… Might get the chance to read the thread now…
    Hi JNSaraiva
    In at a glance of your first requirement looked like you have three specific objects (image, text, otherObjects) and you wanted to move all images on one specific layer and text frames on another specific layer and rest objects to another specific layer. If this what you wanted then my first code will definate full fill it but in your subsequent mail it sounds like you want move every object in your selection on different layer, if this is what you wanted then try my below code:
    var mySels = app.selection.length;
    if (mySels == 0) {
        alert("Select the object and Run the script");
         exit(0)
    else{
    while(mySels--){
              var objLayer=app.activeDocument.layers.add();
              app.selection[mySels].itemLayer = objLayer;
    Mac
    Aug 20, 2011 7:27 AM   in reply to JNSaraiva
    Illustrator does not have an 'itemLayer' property… In ID this property is r/w so objects can be relocated by changing this… In AI you would need to move to each new layer as the page items 'layer' property is r/o…
    Sep 2, 2011 9:15 AM   in reply to JNSaraiva
    When I tried this script, it errors and complains that it cannot move locked objects. I have some layers locked. No
    objects are locked as far as I know. How can the script be adjusted to ignore locked layers?
    Best to you,
    Mike Witherell in Maryland
