CS5 Default substituted fonts
Aug 19, 2011 11:23 AM
I'm asking this question for the editor that I regularly work with on projects. He works on a Windows laptop editing a lot of content that is designed on Intel Macs. We share multi-use fonts through Universal Type client but whenever we use system fonts, we run into the issue where different computers have different versions of the same font. So whenever he opens one of our documents in IC, he gets a missing fonts warning for fonts that he has (Times, Arial, Wingdings, etc.).  Is there a way that he can set those fonts to be substituted by the system font versions that he has so that he can see the approximate flow using the correct font without having to actually replace the font (which would then mean that the designers would have to replace the font again when they reopen the file)?  Hope that makes sense. I know IC uses a default font to substitute missing fonts, I'm just wondering if there is away to permanently assign certain fonts to substitute certain missing fonts.
    Aug 19, 2011 2:50 PM   in reply to E Diane King
    If they're coming up as missing they're not the different versions of the same font...they're different fonts.
    You need to make sure you're using Opentype fonts on all machines.
    Bob
    Aug 19, 2011 7:26 PM   in reply to E Diane King
    The problem is a combination of issues...
    Since you are using OT fonts, don't use the Mac dFonts of Times, Helvetica, Helvetica Neue, or Zapf Dingbats--use the OT version (Times Std, Helvetica Std, Helvetica Neue Std, etc.)
    In fact, remove any unwanted Mac dFonts and TT Collections (.ttc) and use only the OT equivalents.
    To see what fonts you can remove, see http://www.ideastraining.com/PDFs/OSX_FontManagement.pdf
    Then remove the Macintosh version of the Microsoft fonts (Arial, Times NR, Wingdings, Wingdings 2, etc) and replace them with copies of the Windows versions.
    They will work fine and will match cross-platform.
    Dave Creamer
    IDEAS Training
    Aug 19, 2011 8:40 PM   in reply to E Diane King
    > If we could just change the default of the substitute font to show the closest approximate for editing purposes, it would be a good workaround.
    Sorry, that's not possible with InDesign or InCopy.
    The default paragraph style in InCopy/InDesign CS5 and 5.5 is Minion Pro. If you have an older version that is based on Times, you will run into probs if you base paragraph styles on it. Best practice is to not base any custom styles on the default Basic Paragraph Style.
    Check Type > Find Font regularly and make sure you're not using any system fonts. If you can possibly stay away from Times, Helvetica, and Helvetica Neue, do so. They're way too much trouble these days to babysit.
    AM
