Unable to Get the Process that is Submitted
Jun 24, 2010 6:44 AM
Hi all,
            I created a simple process i.e when a task submits in the workspace it will be assigned to a specific user.
when i start a process and clicks complete its working fine,Me not getting any errors.The process is getting submited with out any errors.
But the process in not moving to the specified user. I mean unable to see my process submited in the TODO(i mean in Workspace) of the specified user.
I checked in my server logs i dont have any erros except a few info and warn messages.
These are my log mesages:
2010-06-24 19:20:31,991 INFO  [com.adobe.idp.um.businesslogic.authentication.AssertionCacheManager] Removed [17] expired assertion entries from the cache out of total 57 entries
2010-06-24 19:20:50,741 INFO  [com.adobe.livecycle.reviewandcommenting.dsc.impl.ReviewAndCommenting ServiceImpl] ALC-CSV-001-000-ON ASYNC EVENT : Asynchronous : TaskCreated
2010-06-24 19:20:51,272 WARN  [com.adobe.livecycle.augmentform.FormAugmenterService] The input document that was passed to the operation Insert Workflow XFO Data is null.  No changes to the data will be made.
2010-06-24 19:20:57,788 INFO  [com.adobe.livecycle.reviewandcommenting.dsc.impl.ReviewAndCommenting ServiceImpl] ALC-CSV-001-000-ON ASYNC EVENT : Asynchronous : TaskCompleted
Regds:
N.Sri Harsha
    Jun 24, 2010 7:22 AM   in reply to sri harsha namala
    If you enable Record and Playback, can you see which step is failing?
    Jasmin
    Jun 24, 2010 6:57 AM   in reply to sri harsha namala
    You can use Tracking to find who the server sent the task to if it did not go to your intended user.
    If the task did not go to anyone then the server thinks that your process instance was completed when you clicked the Complete button.
    Ensure that the target user's name is, in fact, on your user service.
    Does the task end up in the Drafts (found in the To Do area) folder for your initiator?
    Are you using LiveCycle ES or LiveCycle ES2?
    Jun 25, 2010 5:14 AM   in reply to sri harsha namala
    Have you tried just restarting you application server?
    I've seen instances where items get queue up and are not being picked up by the scheduler for what ever reason.
    Jasmin
    Jun 25, 2010 5:22 AM   in reply to sri harsha namala
    Can you attach your lca?
    Jasmin
    Jun 25, 2010 7:01 AM   in reply to sri harsha namala
    You Flex form doesn't even submit in my environment.
    Did you build it according to the following guidelines : http://help.adobe.com/en_US/livecycle/9.0/createflexapps.pdf?
    Jasmin
    Jun 25, 2010 7:34 AM   in reply to sri harsha namala
    I was able to load your lca and after changing the users I was able to open the start form and submit it and the task went to the next
    user.  The next user submitted the task; however it did not get written to the file system as per your process but that is another issue.  I am able
    to submit the form and the next user does get the task.
    Aug 23, 2011 8:02 AM   in reply to sri harsha namala
    Have the similar issue unable to get the process sumitted
    Is server reinstall the only solution any inputs appreciated
    dont see any errors in the log the form is reassigned to process initiator but never shows up in the TODO list
    Aug 23, 2011 2:15 PM   in reply to pavan99
    Task ends up completed and not assigned to users in the process
    Jan 26, 2013 7:50 AM   in reply to Jasmin Charbonneau
    Hi Jasmin,
    We are also facing the same issue .... is re-installing the server is the only solution?
    For us all the applications were running fine from past 2 yrs and now suddenly for long lived process - process IDs are not getting creating. Users/approvers are not getting any task in their todo list... nothing is seen in the tracking..
    Any help will be great.
