I'm spinning off versions of some manuals for another division (same product, different paint), and decided that rather than entirely clone parallel FM files, I'd try having the main Flow A be a text inset from the defining instance of the product manual, with division-specific content controlled by Condition Codes. Grave warnings on this forum to the contrary notwithstanding, it works perfectly . But I did run into an oddity while testing.
The clone manual started as a whole-flow paste of the defining content. When I began to test doing it as an inset, I deleted the clone Flow A, which had a Heading1 as the first Paragraph Format. This left an empty Heading1, into which the defining flow was imported, as:
<*> Body Page Flow [ A (Main Flow) ]
<*> Retain Source's Formatting
<*> Automatic
Alas, there were two extra empty pages at the end, due to the Heading1 having Top of Page elected, and due to Make Page Count Even on save.
So I deleted the inset and tried to change the Heading1 to Body.
No go.
I could insert or delete text in that Heading1 (so it wasn't set to read-only), but nothing would change the Paragraph Format.
So I saved it as a MIF. I found these tags:
<Para
<Unique 5547797>
<PgfTag `Heading1'>
<Pgf
<PgfLocked Yes>
> # end of Pgf
<ParaLine
<TextRectID 80>
<String `'>
> # end of ParaLine
> # end of Para
> # end of TextFlow
# End of MIFFile
I've never noticed tag PgfLocked before.
And if you import the inset with
<*> Reformat Using Current Document's Formats
tag PgfLocked is not there.
Changing "Yes" to "No" (MIF hacking) fixed the problem.
Is there a Frame menu item for this? (this is 7.1/Unix)
I'm guessing that specifying:
is what's causing the lock.
Going back as far as FM 3 or 4, until FM9, I've found PgfLocked while troubleshooting MIF from an FM doc that had content imported from a Word doc (not sure now whether it was cut/paste or an actual Import command). Not available through the UI as far as I know.
What's more annoying is that doing a MIF wash doesn't clean them out, either, which is a big PITA and contrary to the whole spirit of MIF washing lore. I don't believe it's documented in the FM9 MIF reference guide, either. Haven't checked any FDK reference material, it might be shown there.
However, all that said, I have used PgfLocked to advantage a few times, as a method to have good control over pesky tag bopping 🙂
... I don't believe it's documented in the FM9 MIF reference guide
It's certainly not in Help. And it's had no mention here (at least based on a quick googling).
I probably never noticed it before because it's probably never been in any MIF I hacked.
Meanwhile, back at the culprit:
I found two more reasons to avoid this option on text insets:
And this is the case when when all of the documents involved share the same pfg/ch formats and variable defs.
fixes both of these problems, plus the <PgfLocked Yes> issue.
... I have used PgfLocked to advantage a few times ...
It appears to be loaded with traps for the unwary.
Another weirdosity I noticed about the locked Heading1 was that although I could alter the text in it, if I hit [Return] and started a new paragraph, it was another locked Heading1, instead of Body, which was the defined Next Pgf Tag. Some things are locked, some not, undocumented all.
The tag strikes me as a some sort of refugee from Structured Frame that escaped into Classic Frame.
