I'm trying to install flash 10.3 in IE 8/Firefox 3.6 and both give an error:
"A required file (c:\windows\system32\macromed\flash\flashutil10v_activex.exe:5) could not be written due to insufficient permissions."
Help is needed...
Thanks in advance.
João Moreira
And i'm installing as administrator.
Tks Vishal, but that's the executable that's online at adobe website, which i've already tried.
- More, i've also downloaded archived versions and error persists for the corresponding file of which version. With an uninstall/reboot/order order;
- Also tried using SUBINACL with RESET_FP10 from http://kb2.adobe.com/cps/494/cpsid_49419.html, and nothing.
Help is needed...
After you run the uninstaller, what files do you have in C:\Windows\system32\Macromed\Flash ?
If there are still any files left, try to delete them manually. Make sure no browser or messenger application is running during the uninstall/install.
If you still get the error when trying to reinstall, please list the contents of the FlashInstall.log file in the install folder.
After running successfully 'uninstall_flashplayer10_3r183_5_win.exe', 'FlashInstall.log' was the file that stayed in 'C:\Windows\system32\Macromed\Flash':
Did a reboot and run 'flashplayer10_3r183_5_winax.exe' which gave the same error "A required file (c:\windows\system32\macromed\flash\flashutil10v_activex.exe:5) could not be written due to insufficient permissions."
Here is 'c:\WINDOWS\system32\Macromed\Flash\FlashInstall.log' with uninstall/install log:
=O====== M/10.3.183.5 2011-08-25+10-08-05.681 ========
0000 00000010 "C:\Documents and Settings\Administrator\Desktop\uninstall_flashplayer10_3r183_5_win.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0037
0038
0039
0040
0041
0042
=X====== M/10.3.183.5 2011-08-25+10-08-09.509 ========
=O====== M/10.3.183.5 2011-08-25+10-11-22.948 ========
0000 00000010 "C:\Documents and Settings\Administrator\Desktop\flashplayer10_3r183_5_winax.exe"
0001
0002
0003
0004
0005 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash10v.ocx
0006 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.exe
0007
0008 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_ActiveX.dll
0009
=X====== M/10.3.183.5 2011-08-25+10-11-29.917 ========
I'm getting this behaviour:
Have you tried uninstalling, deleting the Flash folder, then installing?
Problem solved. =D
. Deactivate Mcafee;
. Install with no problems.
Thanks to all.
Regards.
