I've got a 2010 Macbook Pro with 8GB RAM and an nVidia card. CS5 worked great on it, but CS5.5 is a different story. I can create projects, import footage, save, and reopen, but when I add a few items to the timeline, save, and close the project or program, the problems begin. Premiere crashes every time I attempt to reopen the project. I've tried using different drives, different types of footage, logging in as administrator, and a complete reinstall. No success.
I informed Adobe tech support of the problem and uploaded crash logs from the program and OS X for them to view. The really annoying thing is that they've promised twice to call me back in a few days after bumping up the problem to a higher level of tech support, but failed to do so.
Any ideas? I'm still able to use CS5 on this machine but it's extremely annoying that 5.5 is completely useless to me.
Interesting. Mine is the mid 2010 MacBook Pro with i7 processor and NVIDIA GeForce GT 330M graphics processor. Same for you?
The odd thing about this problem is that it only crops up after I've added items to the timeline (doesn't matter what - stills, video, whatever) then saved, closed, and attempted to re-open. Happens in user or admin mode. I briefly see the hourglass, then the program snaps closed (sometimes with a brief flash of white screen).
Done. On another suggestion on Creative Cow, I also uninstalled CS5 and CS5.5 and ran the Adobe CS Cleaner Tool. Restarted the computer and reinstalled CS5.5. Same result, unfortunately. If I add anything to the timeline, close and save, then attempt to reopen, the program crashes after a brief display of a white screen and stopwatch.
Still no return call from Adobe tech support either.
Thanks for the information, Chad. It solved the problem! I had tried the GPU "hack" with CS5 (it worked - but didn't seem to improve performance) but not CS 5.5. Evidently, just having the CUDA extensions and preference panel installed in OS X were causing problems. I removed them and did a reinstall of the OS. Voila, problem fixed.
Thanks also to Todd Kopriva for looking into this for me.
Howdy Michael, I had tried the CPU "hack" with CS5 to make it recognize the 2010 MacBook Pro's GPU as an approved CUDA card. Part of this process involved installing the nVidia CUDA extensions and preference panel. Chad noticed this in my system profile, and suggested it as a possible cause of the crashes I was experiencing. Although I didn't try the hack with CS 5.5, it appears that the CUDA extensions I had earlier installed were the source of the problem. Won't be an issue with 2011 MacBook Pros as they use ATI cards. Bottom line: be wary of "hacks".
Hello Chad. I was reading the post with regards to the 2010 macbook pro crashing pretty consistently when bringing up Premiere Pro CS5.5 with media linked/in the time line/ I am getting a similar symptom. My case number is 182894346 and was hoping you could help steer me in the right direction with the solution for Bob's problem posted above. it may be the same issue, but i did not see the technical solution, only the result was fixed. Thank you very much.
I went directly through Adobe technical support, David. The first level of help was fairly generic and didn't solve the problem, and they eventually forwarded my case to Chad and he suggested the solution that worked. I would suggest going the support route. Be sure to follow up regularly until they have a solution. I found the process fairly slow, but posting on forums monitored by Adobe employees seemed to help when things got bogged down.
Thanks Bob. I will do that. I have narrowed ot down in linking to ProRes files. It is not consisent, but I get can it to repeat if I open Premiere when the project has linked ProRes files on either the internal or external drives. DOes not happen everytime, but can get it to occur often. When I remove the ProRes media links in the project window, I cannot get the system to crash at all. I am coming from FCP 7.0.3 and have been using ProRes on this macbook for a couple of years. Just transitioning to Adobe (maybe) and upgraded to Lion recently
If anyone has any thoughts on this, please feel free... I have been trying to reproduce for the past 3 days. Premiere 5.5.2 on Macbook Pro (2010) Lion 10.7.2. Premiere launches a project with nothing in the timeline, only files in the the project window. The application either successfully launches and the media links (several formats QT ProRes, H/264, R3D, etc...) or crashes while trying to link media. I have tried differnt types of media and removing others. Never seems to be a problem with MPEG-4, R3D, etc... but the Quicktime movies (ProRes, but not only) seems problematic. This is completely inconsistent. I am not changing anything, just simply binging up the same project over and over. The application will crash or successfully launch randomly. May get 4 or 5 successful launches and then next one is a crash. May crash 2-3 times in a row. Then successfuly launch again for the next serveral tries. I can tell when the application launches whether it will crash or not. I can hear my drive when the app tries to link media and everytime it succesfuly launches. When I don't hear my media drive after lauch, I know it will crash - and does every time. If I remove all Quicktime media references/links and only leave MPEG-4 and/or R3D I cannot get it to crash. However, no consistency in the crashes with the Quicktime media. Any thoughts?
MacBook Pro (2009) 3GHz, Intel Core 2 Duo, 8 GB with 256 SSD internal, Lion 10.7.2 (pretty high end mac laptop). External drives are G-SAFE, SSD 256, Promise SmartStore, etc... all sorts of variations with FW800. Thought it was external media drive issues at first, bt b een testing and narrowing down for several days. SImplified it down to no external drives and two small media QT files on my internal drive (SSD) and still crashes often. Premiere will launch and crach within a few seconds while trying to link files (so it looks like). In the project window, the icons for the media files will change to video, movie icon etc.. when all is fine and the app stays up. I can tell when it is about to crash when the app launches and the media file icons remain unknown for several seconds then it seems to time out and crash within a few seconds. All I do is try to bring up the project again and it will either do the same or launch successfully. no rhyme or reason. sometimes it works sometimes it crashes. i just keep trying until it launches and media files link... then all is fine and I can edit. VERY frustrating and makes me not at all confident about the product. But, I realize it is something very strange and probably system-specific related. Can't imagine this is a normal problem with Premiere. Just feel its like a needle in a haystack. I tried reinstalling Lion, clearing cache, etc... with Adobe tech. just don;t know where to go from here/?? Thanks again for your comments.
