My image files will NOT show up when I import them
Nov 12, 2010 7:14 PM
I CANNOT see my image files when I import them. This is the case regardless of whether I import them directly from my image files, or from my Flash library. They WILL NOT show up in the stage area, although the panel on the right shows the file! What can I do to correct this? I am using Flash CS4 which I need for my Digital Design classes through the Art Institute of Pittsburgh! I will FAIL this course if I can't get this program to work properly!!
    Nov 12, 2010 9:22 PM   in reply to WolfmanJack1959
    Here are a few things to check:
    Do you have anything else on Stage that might be covering them up? Is your target layer locked? Is the layer visibility turned off?
    Are you doing this in an existing document, or a brand new document?
    Nov 12, 2010 9:32 PM   in reply to WolfmanJack1959
    Did you tried with import to stage option.By default the images will load in to library so if you need to seethem you must drag them on to the stage.
    Nov 13, 2010 1:44 PM   in reply to WolfmanJack1959
    If it is indeed a Flash problem, you should try updating. Perhaps there's a fix. I've never heard of a bug like that before, though.
    Aug 27, 2011 9:10 PM   in reply to WolfmanJack1959
    I don't know if you've solved this already but I had the same problem.
    Then I realized that under VIEW, PREVIEW MODE was set to OUTLINES instead of FULL.
    Aug 27, 2011 9:17 PM   in reply to adobe1kenobe066
    Good suggestion, adobe1kenobe066!
