AIR 2 Support in CS5 Extensions
Aug 29, 2011 8:22 AM
Is there any way to use the AIR 2 runtime in CS5 Extensions? I need the ServerSocket class real bad...
TIA,
mlavie
    Aug 29, 2011 8:27 AM   in reply to mlavie
    Yes you can. Download the Air 2 SDK, and then follow the instructions here: http://kb2.adobe.com/cps/495/cpsid_49532.html
    Regards
    Aug 30, 2011 1:50 AM   in reply to mlavie
    AIR 2.0 SDK might be the maximum you can use with Flex 3.4, though off the top of my head I am not entirely sure.
    I would try again with AIR 2.0 SDK.
    By the way, since Extension Builder 1.0.2, and CS SDK 1.5, the bundled Flex 3.4 SDK should already have an AIR 2.0 SDK overlay. If that's not what you've found please let me know which product and version you are using and someone can look into it.
    Aug 30, 2011 3:53 AM   in reply to mlavie
    Yes, CS SDK 1.5 was released a few months ago - see the downloads section on this page http://www.adobe.com/devnet/creativesuite/cs-extension-builder.html
    The free SDK has changed little since 1.0, but the AIR SDK overlay should now be present.
    Aug 30, 2011 4:04 AM   in reply to mlavie
    You can also download the Extension Builder 1.5 trial (linked to on the page David posted above) - as well as including the CS SDK it will also let you develop extensions "the easy way" :-)
    I believe the trial will be running for another few months at least.
    Louis
    Aug 30, 2011 4:49 AM   in reply to mlavie
    Yes, the Flex 3.4 SDK contained in CS SDK 1.5 can be used to build CS5 and CS5.5 extensions.
    It is the same as it was in the CS SDK 1.0 release except it contains the AIR 2.0 SDK overlay.
    Nov 2, 2011 7:07 AM   in reply to mlavie
    Hi
    If you place your code containing NetworkInfo into a simple Air app, does it work?
    Regards
