Hey,
We desgined a process long-lived and wanted to autogenerate the BAM dashboards now by just clicking the checkbox in the configuration screen. But somehow the BAM dashboards for this process do not get generated they are missing.
What is the best way to make this happen ?
We tried to undelpoy and deploy the process again, nothing changed. Also deleting the process and reimporting the process show the checkbox is clicked but the dashboards don't get generated.
any hint is welcome, we use ES2 with SP1 on a JBOSS system with turnkey installation
thank you
Dieter
The only thing you should have to do is check that checkbox and deploy the process.
Can you check if you have any error in the BAM app server log. It should be under C:\Adobe\Adobe LiveCycle ES2\jboss-bam\server\all\log\server.log if you use a turnkey install.
Jasmin
there is nothing special in the server.log which relates to this ...
when makeing a new process on the system and checkbox the auto generation the process gets it own folder on the bam dashboards and populates. seems to work fine, how ever on the one we had already designed and tested and run several times is not making this :-(
seems like a bug
would SP2 fix this maybe ?
thank you
Dieter
just to close the issue loop here, the fault was in the size of the name of the process. once the name of the
process was corrected to a max.24 characters (including fullpath) the generation worked.
alternative you can alter the size of the tables fields to 255 ...
