Does anyone have an ANT build file for an ADEP project I could look at?
Never mind - answered my own question:
<project name="Basic Tiles Build" default="dist">
<property environment="env" />
<property name="output.dir" value="../../catalogs/Tiles" />
Sets the "mosaic.sdk.dir" using this precedence:
1. MOSAIC_HOME system environment variable
2. Relative path that is the grandparent of this script's directory
<condition property="mosaic.sdk.dir" value="${env.MOSAIC_HOME}/sdk">
<isset property="env.MOSAIC_HOME" />
</condition>
<condition property="mosaic.sdk.dir" value="${root.dir}/sdk">
<available file="${root.dir}/sdk" type="dir" />
</condition>
<condition property="mosaic.sdk.dir" value="${basedir}/../../../../sdk">
<available file="${basedir}/../../../../sdk" type="dir" />
</condition>
<condition property="mosaic.sdk.dir.found">
<isset property="mosaic.sdk.dir" />
</condition>
<fail message="Failed to find Mosaic SDK" unless="mosaic.sdk.dir.found" />
<echo message="Mosaic SDK ${mosaic.sdk.dir}" />
<property name="FLEX_HOME" value="${env.FLEX_HOME}" />
<taskdef resource="flexTasks.tasks" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar" />
<!-- Clean -->
<target name="clean">
<delete dir="bin-debug" />
</target>
<!-- Build -->
<target name="build">
<antcall target="-build">
<param name="file.name" value="ComplexContextSetGet" />
</antcall>
<param name="file.name" value="ComplexContextWatcher" />
</antcall>
<param name="file.name" value="ContextWatcher" />
</antcall>
<param name="file.name" value="MessageReceiver" />
</antcall>
<param name="file.name" value="MessageSender" />
</antcall>
<param name="file.name" value="SetAndGetContext" />
</antcall>
<param name="file.name" value="RetrieveData" />
</antcall>
</target>
<target name="-build">
<antcall target="compile">
<param name="target.dir" value="bin-debug" />
<param name="debug" value="true" />
<param name="file.name" value="${file.name}" />
</antcall>
<mkdir dir="${output.dir}/${file.name}" />
<copy file="bin-debug/${file.name}.swf" todir="${output.dir}/${file.name}" />
</target>
<target name="compile">
<mkdir dir="${target.dir}" />
<mxmlc file="src/${file.name}.mxml"
output="${target.dir}/${file.name}.swf"
debug="${debug}"
actionscript-file-encoding="UTF-8"
keep-generated-actionscript="true"
static-rsls="true"
fork="true"
maxmemory="512m">
<load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
<source-path path-element="src/" />
<compiler.include-libraries dir="${mosaic.sdk.dir}/flex/sdks/4.1.0/frameworks/libs" append="true">
<include name="mosaic-tile.swc" />
</compiler.include-libraries>
<includes symbol="mx.managers.systemClasses.MarshallingSupport" />
<include-libraries file="${FLEX_HOME}/frameworks/libs/automation/automation.swc" />
<include-libraries file="${FLEX_HOME}/frameworks/libs/automation/automation_agent.swc" />
<include-libraries file="${FLEX_HOME}/frameworks/libs/automation/qtp.swc" />
<include-libraries file="${FLEX_HOME}/frameworks/libs/automation/automation_dmv.swc" />
<source-path path-element="${FLEX_HOME}/frameworks" />
</mxmlc>
</target>
<!-- Dist -->
<target name="dist" depends="clean,build" />
<target name="smoke" depends="build" />
<target name="all" depends="build" />
</project>
