I have a Network site license for Adobe CS4 Flash. However, my users Settings KEEP deleting because they are stored in AppData\Local instead of AppData\Roaming (Windows 7) or Local Settings\Application Data instead of just Application Data (XP).
In a Network, local settings are deleted on logoff.
WHY on EARTH would Adobe Change this? We have been running Adobe Flash (Macromedia before that) for 10 years and we never had issues with MX, Flash 8, Flash 9 or CS3 but in CS4 all the settings move to the ONE folder that deletes on logoff?
The weird thing is that Dreamweaver CS4, Photoshop CS4, Indesign CS4 and Illustrator CS4, Fireworks CS4 ALL store their settings in the Application Data folder, not the Local one.
It is JUST Flash that is being annoying.
I have upgraded to 10.0.2 and it hasn't made a difference.
I need to figure out the hack to fix this asap as it is driving my users crazy.
I think this issue has to do with Roaming Profiles in Windows, and not something that Adobe has changed.
Here's some more info on roaming profiles:
http://msmvps.com/blogs/bradley/archive/2009/02/21/so-what-is-roaming- in-windows-7-anyway.aspx
http://social.technet.microsoft.com/Forums/en-US/winserverGP/thread/80 789703-82e0-4f48-ac00-e0a4690501c5/
http://blogs.technet.com/b/askds/archive/2008/06/30/automatic-creation -of-user-folders-for-home-roaming-profile-and-redirected-folders.aspx
No it is definitely Adobe. I am an expert on profiles.
It has nothing to do with Windows and everything to do with the location Flash designates as the local storage.
For a decade Flash has used AppData Roaming. Now it uses Local which means in a network environment all local settings are deleted on logoff.
Most people who run Flash don't run it at the level that I do. They have it on their home computers or work computers with local profiles with one computer designaged to one person.
I have a 500 site license with users roaming all over so there is no local profiles.
I am not the only one with this issue. It is documented. Adobe just refused to fix which is very typical of them.
With Flash CS3 it stored it in the AppData\Roaming. In fact ALL the Adobe products still do, except Flash.
Here is the documentation on where they have designated the Preferences to save. Note the "local settings" for XP and the Local for Windows 7.
Kind of very dumb because the Local Settings deletes on logoff..
http://kb2.adobe.com/cps/520/cpsid_52048.html
To save custom commands and other settings, create a copy of this folder:
That is the nature of Domains. Roaming profiles roam between machines. The profile is stored on the server and downloaded to the machine every time they login. When they logoff the profile is copied back up to the server and the profile is deleted off the local machine.
The "local settings" folder is a windows folder created on logon and used as a temporary dumping ground for stuff like temporary internet files and basically all the useless garbage you don't want to keep on your network.
No REAL properly designed programs store anything except temporary stuff in the Local Settings folder because it never gets copied back up to the server, and instead gets deleted.
That is the issue I have with Adobe. They have put Flash settings that only save in the Local Settings so even in a Domain where users have modifiable profiles, the settings get deleted whenever they logoff.
Hi lallsopp,
Thanks for your feedback on this. I can see how this storage location could be problematic for some users that have roaming profiles.
Please let our development team know directly that this is a problem for you:
In your submission, be sure to include details as to why this is negatively impacting you and/or include a link to this forum thread.
function(){return A.apply(null,[this].concat($A(arguments)))}Carey Burgess wrote:
Hi lallsopp,
Thank you Carey. I have reported it.
I've written a script that may serve as a temporary hotfix for some situtations:
http://ajarproductions.com/blog/2011/09/01/script-backup-and-restore-f lash-pro-config-files/
function(){return A.apply(null,[this].concat($A(arguments)))}Justin Putney wrote:
Well that was very nice of you =). I have a simple logon script that copies the files up and down to the server on logon and logoff but I will look at this. Thanks.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
