I have the same problem - the printer works fine witrh everything else and was fine with Acrobat Reader prior to the upgrade to 9.
Reisntalling the printer driver is all well and good but the upgrade process is poor if this is a requirement! Think about all the corporates with locked down settings for example.
I had the same problem as you described: I get the "error, no pages selected to print" even though pages are clearly selected to print in the Print dialog.
I am using Adobe Reader on XP/SP2. I deleted and reloaded the printer, HP LaserJet 5200, and rebooted... same problem. I checked for updates for Adobe 9, loaded them, and rebooted...and was able to print for about a week. Then the problem came back again.
I noticed that in the Print dialog->Printer Properties button...Printing Shortcuts dialog...re-select all the drop-downs (i.e. Paper source=automatically select, Paper size=Letter, etc.) and press ok. Seems as if this resets the setting the Print dialog is looking for and Adobe prints the document (at least it did for me, your situation may be totally different, but its something to try).
I just encountered this problem after upgrading to V 9.x.
The solution I stumbled on was to click the page icon on the left hand side under the print icon. Thumbnail images of the document are displayed. I selected the pages I wanted from the thumbnail images and hey presto they printed out.
I just ran into this but the page icon trick worked however I had an extra level of weirdness.
I had a three page document that I printed to PDF via cutepdf. I then went into the cutepdf printer preferences and set it to print two pages per sheet.
I then reprinted the 3 -page PDF to cutePDF again ... creating a second PDF with only two pages (page 1 with the original page 1 & 2 and page 2 had the original page 3).
When opened in Reader, the number of pages in the menu bar showed # of 2 but when I clicked on the "pages" navigation panel, it showed the first page as page 2 and the second page as page 3. Weird? Is this due to the reprinting of two pages per sheet or does Reader/Acrobat have a page numbering bug?
Did anyone else that had the "no pages selected problem" notice this page misnumbering/counting problem?
Dave
Easy fix. Go to File, print, advanced button at the bottom, check the "Print as image" check box. OK. OK to print. Or set the shrink to printable area to none and deselect the "auto rotate and center" box. Repair and reinstall fixed nothing when I tried it. The print to image did. What I was trying to print from someone was created in an ancient version of Adobe, if you look at the properties of the doc it says the version it was created in. Might be part of the problem. FYI.
I'm on a Mac (Intel Unibody MacBook OS X 10.5.8) and I am experiencing the identical problem. However, I've read through all the posts in this thread and none of the solutions offered by other respondents to the thread worked for me. When I tried the 'Repair' solution I received a message that 'No missing components detected' 'Repairs are not needed'.
I know this is a free programme but does life have to be this hard - all I want to do is print a pdf file!
If you check through the thumbnails of the document you may find some pages are blank.
When attempting to view these pages you may receive error "There was an error processing this page, There was a problem reading this document (109)"
I believe the file may have been corrupted in transit or error on the creators side. I am checking with the sender.
In any case my user wanted the document printed...
In the Thumbnail Windows I selected all (CTRL+A) and then deselected the few pages which were errored (CTRL+Click).
Right hand clicked and hit print.
Well, I doubt that will work for me - I'm on a Mac so the file structure is different I imagine. Glad that you found a way to make it work though. Sometimes I've been able to open the file in Preview (an inbuilt Mac application) and then I have no trouble at all printing - the problem is when it seems to be an Adobe created file which will only open with Adobe ... don't know why :-(
Cheers
Tricia
I got the same error message but my solution was different to what I read in the above posts - since it frustrated me beyond measures describable here, I decided to try focusing on the printer in stead of selected pages. It turns out that the error message in my case was very misleading. I had no hope of printing to the printer I selected because my IP address and default gateway were still setup for the wrong environment (my home, not my work). I could not log onto the server to which the printer listens. Fixing that, I logged onto the server, and from there, with no changes to Adobe Reader (install/uninstall) or the printer setup, I could print again.
The root cause of the problem is incorrect error reporting. Either Microsoft or Adobe is reporting incorrectly that "No pages were selected" when my system tried to print to a printer that it could no longer access because I was not logged in to the server, and the printer driver could not talk to the service it wanted to talk to. The reported error gives no indication whatsoever to correctly guide anyone to solving the problem.
As Adobe reader is free I'm asking Adobe nicely - guys, could you check out why it would do this and maybe improve future releases of Reader to more accurately report such problems with printing?
I'm still getting the same error message - my workaround (because I'm on a Mac) is that - unless I'm trying to print a doc that was created using Adobe and therefore I can't choose Preview to open the doc - I save the .pdf and then use Preview to open it - it always prints without any problem from Preview. However, it's really annoying with those docs where this workaround can't be used.
I don't think that the IP address is the cause of the problem for me. I use my Mac with both a Canon printer (in Australia) and an Epson printer (in Italy) - same problem in both countries. I have a wireless network in both places and can print from both Word:Mac 2008 and Excel:Mac 2008 over my LAN - I thought I would uninstall and download again to see if that worked but I already did that a few months ago and it didn't change anything.
Thanks for your input ... glad you got it to work for you ...
Cheers
Scadger
For your problem, I'm assuming other programs already print without problem. My only recommendation is backup your system, format, install only your OS and printer, and see if that hits it. Get a fresh copy of Adobe reader, maybe off a magazine CD - the downloads off internet are usually only download managers that install themselves on your system and then download the actual program. Stay away - possible errors can creep in. And maybe stay away from the Adobe Reader install package you have at the moment - mark it suspect. Download your printer software anew.
Basically start fresh. If it works then, I'm guessing a software conflict on your old system is the cause, or your install media you used for your old install was corrupt, only 2 of many possibilities.
But the key here is to make a "ghost" backup of your current system so you can go look for the problem afterwards. Of course, I don't even know if there is backup software like ghost out there for a mac.
Also, I think your mac probably has recovery CDs. Avoid those - get CDs of your OS only. Make sure you install only the OS and printer software - possibly even only the printer driver, not the printer software. The newest latest and greatest versions of all of them.
And easiest probably is to put in a different hard disk for this test - saves you from backing up.
My thoughts are that Adobe Reader should work on your system. It's a software configuration issue. So something you've installed is preventing things from working correctly. Especially since your other programs print to the same printer driver without hassle. But your first step is to get Adobe Reader to print again on a fresh start and prove it still can work, then add stuff until it stops working and blame the last thing you installed.
The actual error, as we've learnt, might be completely unrelated to "no pages were selected".
If you've done all that and still no joy, try a different printer with different software. Then try a different printer cable. Then you've got to move on to changing the machine so you can get away from the ports on your current system, but by this time we're at the point of giving up hope, I hope you don't have to go there. Maybe you could install a peripheral card in your system to add a new port, but that's also more of a hassle than it's worth.
Hope this helps.
I'm having the same problem with Adobe Reader 9 (9.3.4) BUT in my case there is NO error message at all. The whole system freezes. It freezes when I click the Print Icon, it freezes when I click FILE > Print SetUp / Print , it freezes when I open the thumbnail icon, right-click the page and try to print. What else can I do? I did everything this forum suggested, uninstalled, re-installed, repair, etc.
The program doesn't respond at all.
All other programs (Word, Excel) print perfectly. I have Windows XP/SP3.
PLEASE HELP????!!!!
I will be out of the office starting 9/15/2010, and returning on
10/4/2010. In case of an emergency, please contact Mary Struchen at the
agency, Barb Peterson or David Taylor at the bank, and they will contact
Ted if necessary for assistance. Thank you.
>>> clearspace-1990071839-629720-2-3174276 09/30/10 04:21 >>>
http://forums.adobe.com/servlet/JiveServlet/showImage/43074/AdobeError .jpg
PLEASE HELP????!!!!
>>> clearspace-1990071839-629720-2-3174279 09/30/10 04:31 >>>
From your printer control panel, select another default printer and see
if the error occurs.
If it doesn't try reinstalling printer/updating printer driver.
Else post back here..
Thanks SirPsycho1977.
I'm at the office and here is only one network printer (Konica Minolta 350/250/200 PCL) connected. I have a Microsoft XPS Document Writer loaded. I made this the default but it didn't help. Same problem.
Can you recommend a driver. The current one is PCL version 02.0
>>> clearspace-1990071839-629720-2-3174342 09/30/10 04:54 >>>
>>> clearspace-1990071839-629720-2-3174372 09/30/10 05:07 >>>
i received this email. I'm not sure why. it doesn't seem to relate to my
problem.
gjbrns1
g j barnes
Tried downgrading. I installed Adobe Reader 8.2. Halfway through got a message: "You already have a more functional version installed. Installation will now terminate." BUWAAAAHAHAHA!!! More like non-functional! Thought it would automatically uninstal 9 and instal 8.
I will now first uninstal v9 and instal the v8. Wish me luck.
>>> clearspace-1990071839-629720-2-3174381 09/30/10 05:19 >>>
This error message, which I received on both Adobe Reader 9.1 and 10.0, seems to come from a variety of causes. In my case, the cause was trying to print a pdf that was created directly from a scanner using an old version of Acrobat Professional (6.0). In fact, I got a warning when opening that pdf that there was "Insufficient data for an image." My fix was to rescan the document as a jpg, then use Acrobat Professional 6.0 to convert it to a pdf. The new versions of Adobe Reader could then open/print the document without difficulty.
I had this problem relatively recently and only when printing from adobe reader. Since I can print from other applications I tried printing pdfs from photoshop CS3 which I happened to have installed. The document printed without any problems. That makes me think something in Adobe Reader in a relatively recent update must have caused my problems. I'm currently on version 9.4.4. I'm using Windows 7 prof 64 bit and have the latest driver installed for my hp laserjet p2055dn printer. Using Photoshop isn't a permanent answer but it did get me out of trouble. I'm going to try to find a free alternative to Reader now.
I just encountered the same error with Adobe Reader X. It resulted from me disabling "Client for Microsoft Networks" on the LAN connection whilst investigating a network issue. Re-enabled "Client for Microsoft Networks" and I can again print PDFs from Reader X.
I didn't believe it, so disabling stopped Reader X printing again, re-enabling it started.
What is the connection here?
Guys, Girls:
I encountered exactly this same problem today - "The document could not be printed. There were no pages selected."
It took me about 3 minutes to fix it. It appears to me that this problem actually has very little (if anything) to do with Adobe products, and everything to do with correct selection of the "Default Printer" within the Windows OS.
I'm using Windows 7 Pro. I went to the 'Devices and Printers' menu, selected the printer that I wanted to print the PDF to (by this, I mean the conventional paper printer), selected 'Printer Properties' from the right-click menu, and then pressed the 'Print a Test Page' button. Nothing printed, so, I launched the Printer Troubleshooter that comes with Windows.
Seems that I had updated the driver for the (paper) printer, and the wrong driver was active. I re-selected the paper printer that I wanted to print my PDF to, set that as the 'Default Printer', and printed a test page - this time the test page printed. I then went back into the Adobe PDF application and selected the print command again - this time, my PDF printed out on paper as I wanted it to.
So, bottom line, I think the cause of this problem is inappropriate selection (configuration) of the default printer in the Windows operating system. I recommend that anyone having this "The document could not be printed. There were no pages selected." problem first try to print a page from some other application (WordPad, NotePad, Microsoft Word, whatever) and see if your printer works from that other application. If not, then you will know it is a printer selection problem, not an Acrobat problem.
Michael
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
