I have a course that is published to SCORM and imported to an LMS. There is audio on each slide and background audio. When I launch the course from the LMS, everything works fine. If I exit in the middle and then relaunch, it takes me to the slide where I left off, but the audio starts from the beginning of the course.
Any ideas on why this is happening?
I didn't create the movie myself, but am trying to troubleshoot. I asked the developer and she said:
I imported the audio as one file, and then I manually clipped it to synch with each slide. I didn't distribute it across the slides, but did "save as new file" each time I made an edit.
I tried exporting the audio clips, renaming them so they didn't say "(Clip)" at the beginning, then reimported them and republished. Unfortunately, the same problem is happening.
Any suggestions?
Look at each clip listed in the Library and check the Usage Count to see that these are actually used on slides. If they ARE actually all separated onto different slides, I would suggest that something has gone awry inside Captivate and it still thinks it's dealing with a single audio file.
You may need to export all the audio clips out as WAV files, rename them from what they were so that Captivate won't recognise them, then reimport each one back in to replace the file currently on its slide. Perhaps that will make Cp play nicer.
No I don't think whether you did it with MP3 or WAV would make a difference. Just that WAV is always better for preserving audio quality. MP3s tend to 'wear out' because they're compressed quite a bit.
At this stage I don't have any ideas other than that your project might be corrupted. If this is a Cp5 project, try copying all slides from it into a new blank project and see if it does the same trick there. Sometimes that can resolve internal issues under the hood.
That seems to be the best thing to do. Its also discussed on Captivate Blog : http://blogs.adobe.com/captivate/2010/08/audiovideosync_in_captivate_s wf.html.
This Blog is for Audio/Video sync issue, you may use this in future. ![]()
