I am using CP 5.5. I created a small test where I have just 2 question in a question pool. The questions are using the advanced answer options to show some specific feedback. When I insert the questions in to the project using a random question slide, after the user answers where you should be able to press Y or click to move on, I click, but nothing happens. You can't get off the quiz slide. The quiz slides work fine when they are inserted in the project as reqular quiz slides, but not when they are being pulled from a question pool.
Is this a known bug? Is there a workaround? Anyone else run in to this?
Lori
I have the same problem and no solution (yet). See an example on my blog: http://www.dorna.nl/?p=1202
Today I received a message from the supportdesk that this is a bug in Captivate. The supportdesk made a bugreport it and advised me to do the same. If you also want to report this bug: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
I was having the same problem on the last Random Question slide (total 10 RQ slides), and was able to fix it by following the next steps:
Make sure Quiz: Pass or Fail actions are set to Continue for both Passing and Failing actions in the quiz preferences.
Delete the RQ slide not advancing, then duplicate one of the RQ slides working, and assign your question pool to the new slide if different from the original duplicate. This step will make sure you are using a good working RQ slide.
For some reason, my last RQ slide was corrupted and wasn't advancing to the Score slide at the end of the quiz.
I can finally finish this project.
Good luck.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
