Magic Bullet Denoiser crashing Premiere Pro and AE CS5.5
Aug 27, 2011 4:53 PM
Is anyone else having problems with Denoiser in either programmes? Possible solutions?
    Aug 28, 2011 12:45 PM   in reply to Bliksem7
    YES !!!
    Possible solutions?
    Not that it might be called a 'solution'...
    Since MB DeNoiser works more or less predictable in CS5, it's possible to create AE composition with DeNoiser applied there and then import it to PrPro.
    (Personally have no problem with importing AE CS5 comps via Dynamic Link directly into PrPro CS5.5, but unable to even open them in AE CS5.5... )
    Sep 4, 2011 12:40 PM   in reply to Bliksem7
    Yes! It crashes on almost every shot that it is applied to.
    The footage is HD 1080p25. AE CS5.5
    Unfortunately, this makes it impossible to get the AE render job run through and also throws off BG Renderer.
    I hope there will be a fix soon.
    Sep 4, 2011 2:09 PM   in reply to andi_urra
    File a bug report with Red Giant.
    I did for Looks 2 and ColoristII in CS5.5
    They recently fixed the bugs.
    Sep 4, 2011 3:07 PM   in reply to Ann Bens
    Hi Ann,
    thank you very much. I hope this gets fixed. The bug seems to be known
    in the web for some time now. I found it in some forums. However, nobody
    seems to know a cure. It is also filed on
    http://aeerrors.myleniumstuff.de/?cat=25&paged=2
    I followed the recommendation of updating the software and the graphics
    drivers but it did not help.
    I would be happy to be able to use Denoiser again.
    Kind regards,
    Andreas
    Am 04.09.11 23:09, schrieb Ann Bens:
    Sep 5, 2011 9:36 AM   in reply to Bliksem7
    Yup, crashes like crazy.
    I've had a lengthy support case with Red Giant testing and reporting to them.. to make the story short, they told me the product is very problematic for them, & I've been waiting for a fix for nearly a year now.
    Got to the point I just bought Neat Video ha.  It was worth it.
    The only "work around" I found with Denoiser was to use dynamic links.  It seemed to crash far less often if I was rendering an AFX clip insidet Premiere Pro rather than AFX.  It still caused various issues where the background AFX process crashes, then the clip goes offline and needs relinked.
    Maybe it'll get fixed one day... maybe abandoned like Steady was. :)
    - wb
    May 4, 2012 3:00 PM   in reply to Bliksem7
    Christ, I've uninstalled & reinstalled and tried numerous other things to try and discover the problem and after all that it was simply because i was using denoiser on a clip. Jeez. What a waste of 6 hours of research. Think i will just live with a slightly noisy image from now on!
    May 8, 2012 1:28 AM   in reply to Bliksem7
    As much as I love Red Giant products, they continually crash every editor I use them in.  Looks has been beyond unstable in Final Cut, and ToonIt! is currently killing Premier Pro for me.  God bless 'um, but the solution is probably to use another plugin.  I've been fighting with this problem with various version updates, "fixes", and promises for 5 years now, and I've had it.
    May 8, 2012 6:56 AM   in reply to HCKPro
    Any DeNoiser owner should be able to get the ALL NEW DeNoiser II for FREE, check here - http://www.redgiantsoftware.com/blog/2012/02/28/magic-bullet-denoiser- ii-is-here/
    Jeff Pulera
    Safe Harbor Computers
    Jun 19, 2013 12:42 PM   in reply to Bliksem7
    i had a similar issue, i would attempt to apply the denoiser II effect on my clip and i wouldnt really see any difference, when i went to render i would say there was an error compiling movie - and simply wouldnt render
    i then proceeded to attempt it in after effects and applying as an adjustment layer and it only crashed
    i then went back to PP and deselected "Use GPU" in denoiser II- effect controls  (its beneath frame sample) and its working! slow as heck but works
