[CS5] Exporting PDF with PDF/X-1a:2001, get CMYK Error
Sep 8, 2011 8:30 AM
Hello,
I'm trying to create a new PDF Export Preset that specifies the PDF/X-1a:2001 standard. All I'm trying to test with is a brand new document with all default values. It works fine if I use my preset in my desktop InDesign, however, if I run a script that attempts to export the same exact document on our InDesign Server, I get an error "warning" which causes the script to fail:
WARN [Server] Color in one or more placed graphics cannot be represented as CMYK. Non-CMYK color is not compliant with the PDF/X-1a standard. You can click OK to produce a valid PDF, but it will not be a PDF/X-1a compliant file.
So my question would be, 1) what part of a blank document is not CMYK compliant? and 2) is there a way to force a conversion of anything non-CMYK to CMYK?
I should also note that I don't think the issue is with my Preset that I made, I've tried using the built-in [PDF/X-1a:2001] Preset as well in my script, which returns the same error.
Thanks in advance!
-Lloyd
    Sep 8, 2011 9:09 AM   in reply to lhanneman
    You probably added an RGB color the the app of your server at one point.
    Remove all app.swatches which are RGB (or remove them all except for the ones that can't be removed), and your problem should go away.
    Sep 8, 2011 9:28 AM   in reply to lhanneman
    Why don't you just convert the color to CMYK in your PDF Preset?
    The default PDF/X1a preset does exactly that...
    Harbs
    Sep 9, 2011 7:55 AM   in reply to lhanneman
    Maybe.
    It could be the result of flattening the watermark.
    What happens if you change the Transparency Blend Space to CMYK?
