Custom check in dialog
Sep 13, 2011 4:44 AM
we are currently implementing a custom check-in dialog for Bridge.
The dialog contains a Combobox.
The available items in the combobox are loaded from a web-service, called from Bridge. How is it possible to provide the Flex UI with data from Bridge?
    Sep 13, 2011 10:19 PM   in reply to JoeriADAM
    for the setContextInfo() function, you should write it like the below:
    public function setContextInfo(info:Object):void
         if(info == null
              return
         var items:Array = new Array();
         if (info.hasOwnProperty("key1"))
              items["key1"] = info["key1"];
         if (info.hasOwnProperty("key2"))
              items["key2"] = info["key2"];
        workflowCombo.dataProvider = items;
    The context info object sent from your Java connector will be wrapped into a generic Flex Object class instance, all the keys will become its properties, all the values will become property values. you cannot cast it directly into an Array instance.
    Gang
    Sep 14, 2011 8:33 PM   in reply to JoeriADAM
    Sorry for late response.
    There are two reasons causing your problems.
    1) It's too early to bind Combobox in the SetContextInfo() function, SetContextInfo() function is called by AdobeDrive in the ModuleLoader.ready Module Event handler, during this time, the creation of Combobox is not finished, you should simply preserve the context info passed to you in SetContextInfo(), then bind Combobox with it in its creation complete event handler.
    2) The dataprovider of ComboBox should be an ICollectionView instance, Array class doesn't meet this requirement
    The sample code is as follows:
    protected function module1_creationCompleteHandler(event:FlexEvent):void
        if (_contextInfo == null)
         return;
        var items:ArrayCollection = new ArrayCollection();
        items.addItem("value1");
        items.addItem("value2");
        testCombo.dataProvider = items;
    Sep 16, 2011 12:30 AM   in reply to JoeriADAM
    I tried to reproduce the issue with your code on my side, however everything was fine, the source code is attached below, please try it
    <?xml version="1.0" encoding="utf-8"?>
    <mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400"
         height="100" implements="com.adobe.drive.customui.moduleinterface.ICustomCheckInUI" creationComplete="module1_creationCompleteHandler(event)">
    <mx:Script>
      <![CDATA[
       import com.adobe.drive.customui.moduleinterface.ICustomCheckInUI;
       import mx.events.FlexEvent;
       import mx.collections.ArrayCollection;
       private var _contextInfo:Object;
       public function setLocale(locale:String):void
        return;
        _contextInfo = info;
       public function getWidth():int
        return 400;
       public function getHeight():int
        return 100;
       public function getInteractionResults():Object
        var returnValue:Array = new Array();
        returnValue[key] = value;
        return returnValue;
         return;
        if (_contextInfo.hasOwnProperty(defaultValue))
         this.TestPropertyValue.text =  _contextInfo[defaultValue];
        items.addItem(value1);
        items.addItem(value2);
    </mx:Script>
    <mx:Canvas width="100%" height="100%" borderStyle="inset">
      <mx:Label id="TestPropertyName" x="32" y="37" text="TestProperty:" width="100"/>
      <mx:TextInput id="TestPropertyValue" x="195" y="35" width="164"/>
      <mx:ComboBox id="testCombo" x="32" y="64"></mx:ComboBox>
    </mx:Canvas>
    </mx:Module>
    Sep 16, 2011 1:50 AM   in reply to JoeriADAM
    No, on my side, requestItem.getCustomParameters() returns the correct interaction result
    item CheckInRequest$Item  (id=212)
     content InputStreamReadableByteChannel  (id=214)
     contentSize 109753
     customParameters CustomParameters  (id=219)
      parameter HashMap<K,V>  (id=223)
       entrySet HashMap$EntrySet  (id=231)
       keySet null
       loadFactor 0.75
       modCount 1
       size 1
       table HashMap$Entry<K,V>[16]  (id=224)
        [0] null
        [1] null
        [2] null
        [3] null
        [4] null
        [5] null
        [6] null
        [7] null
        [8] null
        [9] null
        [10] null
        [11] null
        [12] null
        [13] null
        [14] null
        [15] HashMap$Entry<K,V>  (id=225)
         hash -922089969
         key "key" (id=143)
         next null
         value "value" (id=144)
       threshold 12
       values null
     identity RemoteAssetIdentity  (id=221)
     lockToken null
     mimeType null
     modificationDate 1307635200000
     replace false
     versionProperties null
     xmp null
    Please do the following steps to re-test your connector
    1) unmount all the drives
    2) kill CS5ServiceManager
    3) make sure getInteractionResults() in the Flex part return the correct value
    4) Compile you Flex module and replace the old one
    5) re-connect your server
    Sep 16, 2011 2:36 AM   in reply to JoeriADAM
    Please use Flex SDK 3.5 to compile your module swf, and give it another try
    thanks
    Sep 16, 2011 3:09 AM   in reply to JoeriADAM
    This is what I got, , I still can not reproduce your issue
    item CheckInRequest$Item  (id=593)
     content InputStreamReadableByteChannel  (id=596)
     contentSize 75579
     customParameters CustomParameters  (id=597)
      parameter HashMap<K,V>  (id=598)
       entrySet HashMap$EntrySet  (id=666)
       keySet null
       loadFactor 0.75
       modCount 1
       size 1
       table HashMap$Entry<K,V>[16]  (id=599)
        [0] null
        [1] null
        [2] null
        [3] null
        [4] null
        [5] null
        [6] null
        [7] null
        [8] null
        [9] null
        [10] null
        [11] null
        [12] null
        [13] HashMap$Entry<K,V>  (id=602)
         hash -199977139
         key "myKey" (id=584)
         next null
         value "myValue" (id=585)
        [14] null
        [15] null
       threshold 12
       values null
     identity RemoteAssetIdentity  (id=594)
     lockToken null
     mimeType null
     modificationDate 1307894400000
     replace false
     xmp null
    MXML file, could you totally use this file for your test and see what happens?
     <mx:Script>
      <![CDATA[
        return;
        return 400;
        return 100;
        var key:String = myKey;
        var value:String = myValue;
        return returnValue;
         return;
     </mx:Script>
     </mx:Canvas>
    </mx:Module>
    Sep 16, 2011 6:46 AM   in reply to JoeriADAM
    It's really strange, if you don't mind, can you share you whole Flex project with me? you can zip it and send it to gzheng@adobe.com, I will compare your project setting with mine and test it with BR5.5
    Sep 28, 2011 9:41 PM   in reply to JoeriADAM
    Yes, there is an issue here in adding a new file using Bridge, the main reason is, it's hard to extract the server information at that time, we will find out how to correct it in the future releases, a bug will be logged.
    please recommend your users to copy the file into AD file system using Explorer/Finder first, the file status is new, then use Bridge to check-in it.
    Thanks for reporting it.
    Gang
