Hi notiles,
Can you please report your issue in our public bugbase? https://bugbase.adobe.com/?event=newBug
I tried to see your problem but I couldn't reproduce by typing '@' in my keyboard. Also I tried entering © or ¢ by using Alt Gr key but it simply not accepting such key control which is depend on program (swf) you used.I appreicate your help to report this issue more in details at our public bug system.
thank you,
Hitomi
dave milbut wrote:
that link needs to be put someplace in big bold at the top of the forum.
There are also direct download links in the FAQ of this forum:
Where can I find direct downloads of Flash Player for Windows or Macintosh?
niraj.swami wrote:
As of 8/30/2011 - we are still experiencing text display issue. Now that all text renders, it seems that the multiline text is being cutoff (at single line).
Please advise.
Niraj
Hi Niraj,
Could you take a look at the following bug and see if it also applies in your case? If so, I would like to recommend you vote and comment for it.
[Platform_Windows]Some multiline dynamic text getting cut off to single line instead of wrapping
Chris
Bloodwras wrote:
I can't click anything in lion using this version.
Can you go to the About Flash Player page and verify your installed version? What are you trying to click on that isn't responding?
Chris
I went there and it said "You have version 10,3,183,7 installed". I was trying to click into my flash settings because it was asking me about using my camera and allowing storage but I couldn't click anything I ended up having to go to my system preferences and using those settings. But I find it quite annoying I can't click any of my flash settings when i right click into them..
Are you using iMac7 or iMac8? Can you let me know your Mac machine's model? Here are some instructions on how to get Mac machine's information from Apple system profiler.
1. To enter into Apple System Profiler you can:
2. In Hardware Overview section, you will find out your Mac machines Model. Below is an example I copied from my MBP's system profiler.
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro8,2
BTW, can you also let me know your Graphic cards type? You can find graphic cards information in system profiler too.
yanzhou.adobe
Ok, thanks for the additional information. This is indeed a known issue and we're working with Apple to resolve this. In the interim, could you try to either:
Chris
how do i make this piece of ******* **** work under limited account in windows xp pro???
"You must have administrative privileges to install AdobeR FlashR Player. Please log on with administrative privileges and try again blabla"
i've already installed it under admin but it doesnt work under limited account! ****!
Vitzkrieg wrote:
ETA on a new Flash Player release? We're getting hammered at work from our clients on when our products are going to be updated and working again...
Nothing definitive yet, though we something should be out in the next few weeks. What sort of problem are you having? Have you verified that it's fixed in our RC build that we have up on Labs?
Chris
valeman31 wrote:
What need to mainly focus on is fixing the lag is the one probally causing all these other issues. (It started happen after 10.3.183.5) Perfromance Slowdown countines. Even try cleaning it its fast in the beginning than it gets laggy so it must be memory leak they never notice.
Do you have any example URL's (or bug numbers) you can give me? I know of one animation slowdown that was introduced in 183.5, but we fixed it with .7. I'd be happy to investigate further. In addition, have you tried our Flash Player 11 rc release? If not, I'd highly recommend it. Its very close to final code.
Chris
The feature request is now available at the following address:
Adobe closed the above "feature request" saying that it is "not a bug"... To lighten up the treasure hunt, the html page now includes a link to download the latest version. The control panels remain a mess, both the installed one and the remote one, the updates will continue to be applied by hand, the swf plugin in Acrobat will continue to be out of sync and both open to security attacks...
In July we spotted a Mac OS 10 with Acrobat 8 that did not want to upgrade. The Acrobat page did not want to list version 10, so we had to force the right update by hand, via the usual treasure hunt to bypass the faulty automatic selection.
Another problem, related to flash, is that the Acrobat plugin stopped working with the introduction of Safari 5.1 on Mac OS 10.7.1.
None of the above problems is in the agenda for Flash 11, and its pre-release does not introduce solutions.
I've been having the same issues since July. A friend of mine pointed me to this thread and mentioned others were having the same issues as me. At the time I was running Windows XP 32 bit and the most current version of flash at that time, using firefox as my web browser. I encountered the same symptoms on both my desktop and my laptop pc, which was and is running Windows 7 and using firefox. I experienced similar problems at the time using IE. Prior to these problems I used to watch videos frequently on sites such as MegaVideo, Novamovies, Megashares, etc. The only way I can describe the symptoms is as another member did... lag. If I watch a video as its loading it seems to work fine, but if I pause the video, it seems like the longer the video is open the slower the playback is. The audio is fine, but the video lags, skipping a large number of frames at a time and "jumping" ahead. I used to be able to pause a video, let it buffer and then come back and watch it days later, but now I can't even go 24 hours.
Since then, I have upgraded to Win 7 on my desktop, I have upgraded my video card as well and no longer rely on my onboard video. I have upgraded to Flash 11, and Firefox 7, and I still have seen these same problems with every update that comes out. The fact that I'm experiencing the same issue with two different pc's tells me that something was changed and not fixed, but I'm surprised this has gone on for so long and not been repaired through many updates to adobe and firefox. I do not know if the problem still occurs in IE. I can check it out. I don't use IE ever.
