Using attachment list as both input and output in UserServiceV2/AssignTask duplicates attachments
Sep 7, 2011 9:16 AM
If I want to pass prior attachments to a user using v2 of  AssignTask I can pass in a list of documents (I'm calling it  attachmentList) in the Attachments tab. If I set Output Attachments to  the same variable, I get any new attachments the 2nd user may have  added, but the first user's attachments are now duplicated. If the  process is repeated, I'll have triplicates from user 1 and duplicates  from user 2.
What is the proper way to go about showing all  prior attachments to a new workspace user while allowing them to add to  the list, without this happening?
    Sep 14, 2011 11:42 PM   in reply to Jack Freudenheim
    use the following XPATH expression in the output attach
    ments variable
    /process_data/attachmentsList[1]
    This will prevent duplicating your existing attachments.
    Apr 13, 2012 5:38 AM   in reply to $Nith$
    This solution is not working for me with LiveCycle ES3
    Approver 1
    Custom Container
    Attachments Tab >
    Input List :  attachList                                                [ datatype List <document> ]
    Output attachments:   /process_data/attachList[1]         [ xpath expression ]
    Approver 2
    Custom Container
    Attachments Tab :
    Approver 3
    Custom Container
    Attachments Tab :
    When approver 3 looks at the attachments any attachments added by Approver 1 are duplicated.
    This duplication multiplies (eg approver 2 attachments duplicated and approver 1 attachments triplicated at Approver 4)  as the form is passed form task to task.
    Any other settings I need to look at ?  Any other solutions out there ?
    thanks
    Apr 19, 2012 1:36 AM   in reply to bugrake
    The configuration looks fine. In ES2 version, it works correctly. I do not know why this problem occurs in ES3.
    Nith
    Apr 20, 2012 6:35 AM   in reply to $Nith$
    thanks nith,
    I will replicate the process in ES2 and check the results....
