First of all I'm running CF9, IIS5.1, XP, Oracle DB.
For some reason whenever I get a JDBC error (I'm almost certain this is the only type that causes this) instead of the standard gray, blue, and black "Error Occured While Processing Request" page I get that page only the HTTP header, a bunch of closing tags, and then the HTML used to create the actual error page.
I was wondering if anyone had any experience with this before and how to possibly fix it.
Can you give an example of the actual output ?
Mack
(This is just the top part, but should give you thie gist)
Server: Microsoft-IIS/5.1 Date: Wed, 14 Sep 2011 19:56:58 GMT X-Powered-By: ASP.NET Connection: close server-error: true Content-Type: text/html; charset=UTF-8 Set-Cookie: CFID=11400;path=/ Set-Cookie: CFTOKEN=84773412;path=/ Set-Cookie: JSESSIONID=8430a389f80b8aa3ffab672b30426fe4e7c6;path=/ Set-Cookie: CFID=11400;path=/ Set-Cookie: CFTOKEN=84773412;path=/ <!-- " ---></TD></TD></TD></TH></TH></TH></TR></TR></TR></TABLE></TABLE></TABLE></A></ABBREV></ACRONYM></ADDRESS></APPLET></AU></B></BANNER></BIG></BLINK></BLOCKQUOTE></BQ></CAPTION></CENTER></CITE></CODE></COMMENT></DEL></DFN></DIR></DIV></DL></EM></FIG></FN></FONT></FORM></FRAME></FRAMESET></H1></H2></H3></H4></H5></H6></HEAD></I></INS></KBD></LISTING></MAP></MARQUEE></MENU></MULTICOL></NOBR></NOFRAMES></NOSCRIPT></NOTE></OL></P></PARAM></PERSON></PLAINTEXT></PRE></Q></S></SAMP></SCRIPT></SELECT></SMALL></STRIKE></STRONG></SUB></SUP></TABLE></TD></TEXTAREA></TH></TITLE></TR></TT></U></UL></VAR></WBR></XMP> <font face="arial"></font> <html> <head> <title>Error Occurred While Processing Request</title> <script language="JavaScript"> function showHide(targetName) { if( document.getElementById ) { // NS6+ target = document.getElementById(targetName); } else if( document.all ) { // IE4+ target = document.all[targetName]; } if( target ) { if( target.style.display == "none" ) { target.style.display = "inline"; } else { target.style.display = "none"; } } } </script> </head> <body> <font style="COLOR: black; FONT: 16pt/18pt verdana"> The web site you are accessing has experienced an unexpected error.<br> Please contact the website administrator. </font>
Also as I learned today it only occurs when robust reporting is enabled
