I've got a video set to "stop on the last frame" using the technique described here:
http://digitalpublishing.tumblr.com/post/6141054971/how-to-make-a-vide o-stop-at-the-last-frame-here
Works great. But whenever I do this, there is a slight darkening when the multi-state object appears at the end. To create the image for the multi-state objects, I opened the video in Photoshop, grabbed the last frame, and saved it as a JPEG.
Anyone have any ideas? I've tried saving the end image as a PNG, lots of other workarounds, but the problem persists. I've noticed this in other publications I've downloaded also, so I think the problem is widespread.
Keith,
i notice this in other publictions too.
if you created the video yourself in aftereffects or premiere, export the
last frame from there.
if this is an external video I would recommend making a snapshot in vlc
player, wich gave pretty exact results for me. (I never trusted the video
import option from photoshop).
you could also try to re-encode the video in premiere and export last frame
from there.
additionally, there is a slight difference in pixel rendering from the iPad
video player and the slideshow display in folio. when a video closes, you
notice a slight shifting of sub pixel positions, resulting in a minimal
"flash" when the video ends.
did you try anything of that already?
—Johannes
I've also had problems with change in lightness between still images and image sequences/videos. I fixed it on my setup by changing the colour settings (on the Edit menu) in inDesign.
Set the working space for RGB to sRGB (or whatever working space Photoshop is currently using). Hope that works for you...
Johannes, David, Octahedra: Thanks for all the suggestions. I've tried all these things with no changes in the results. I spent a couple of hours today trying combination I ould think of with color management, to no avail. I even took a screen shot of the end of the video as it played on the iPad in DPS, and then used that as the underlying MSO image in the ID layout, and it still appears darker than the video. Weird.
It appears to me that videos when played in DPS appear lighter and more "washed out" than when played on the desktop. Also, the desktop DPS previewer doesn't exhibit this behavior.
I figured out an answer to this problem. I wrote the answer up in a blog post here:
http://blog.gilbertconsulting.com/2011/09/dps-stop-video-at-last-frame .html
great to see this trick evolve in a first-frame-lasf-frame-method, wich I
thought about,too lately.
Will post an update in my article next time ii get the chance.
—Johannes
(mobil gesendet)
Am 27.09.2011 15:33 schrieb "KeithGilbert" <forums@adobe.com>:
KeithGilbert http://forums.adobe.com/people/KeithGilbert created the
discussion
"Re: Video set to stop on last frame appears lighter than last frame"
To view the discussion, visit:
http://forums.adobe.com/message/3940255#3940255
I can get this technique to work for me. The video plays for the duration of the interval setting and then gets interupted by the thrid state. I've followed the steps exactly as in the blog post.
Has a recent update changed the behaviour for video in multi state objects?
-Mark
Mark Kunoff
Informational Systems Specialist
IU Communications
Indiana University Public Affairs and Government Relations
