how to export indesign layers to photoshop layers (same structure)
Jul 2, 2009 1:28 AM
  Latest reply: Rob Day, Jan 22, 2014 9:17 AM
Replies 1 2 3 Previous Next
  • Rob Day
    Oct 16, 2007
    Sep 15, 2011 10:50 AM   in reply to mm81bg
    The text layers came rasterized and I actually need them to be recognized as text layers since I would need to key off the info in them...is this possible with some extra preset modification or I'm just asking for too much already
    Sorry the script is saving out PDFs of the layers and the text has to be rasterized when the PDF is opened into PS.
    Sep 18, 2011 1:43 PM   in reply to Rob Day
    Hi Rob,
    Thanks so much for making this script - I've been using it for a long time now and it's been extremely helpful and a great timesaver! I can't seem to get it to work now though, and I'm not sure how to fix it. I actually ran it last week still using the CS3 version script  - even though I'm using CS5 now - it worked great with no problems. But now I'm getting an error message when I try to run the script...I downloaded the new version you posted for CS5 and still no luck with getting it to work. I read through your directions to change the "[PDF/X-4:2007]" to "[PDF/X-4:2008]" (since this is the only PDF/X-4 preset option available to me in InDesign) and also tried creating a preset named "myPDFpreset" (starting the PDF/X-4 preset) and then compiled and resaved the file, but still can't seem to get it running again. I'm not sure if there's any issues with the way I have my file set up or the settings within InDesign, I'm not sure.
    I've attached a sreenshot of the error message I'm getting. Please let me know if you can help! Thanks again
  • Rob Day
    Oct 16, 2007
    Sep 20, 2011 6:40 AM   in reply to sosoclumsy
    Your error message isn't for a missing PDF preset. I'm wondering if something happened when you tried to edit the script. Could you download the script again (from post 32), run it and see if you get a different error message, and post that? My assumption that the PDF/X-4 preset is universally available seems to be causing problems, so I might post a version with a list of presets to choose from when I get some time.
    Nov 1, 2011 2:44 PM   in reply to Arjan_Scholten_Muntz-MCG
    I recieved the same error message as sosoclumsy. I tried re-importing thee script, to no avail. Rob, if you are able to come up with a fix, that'd be great. Thanks for your help!
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 3:14 PM   in reply to anardinelli
    That error isn't for a missing PDF preset it's for something else. At what point do you get the error? Do you get past the two dialogs for folder selection and color mode/res and into Photoshop?
    Nov 1, 2011 3:20 PM   in reply to Rob Day
    Sorry Rob, I got this error, which isn't the same as above. I do, however, get past the first two dialogs.Picture 28.png
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 3:28 PM   in reply to anardinelli
    I can't find anything wrong here. If you can run the script from AppleScript Editor and copy the Replies log for me I might be able to spot the problem.
    Run the script, click the Replies button, copy the text in the lower panel and post the text.
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 3:30 PM   in reply to anardinelli
    Oh wait, I see that your error is the missing PDF/X problem. Nevermind about the log I'll post a fix.
    Nov 1, 2011 3:47 PM   in reply to Rob Day
    For some reason I didn't get an email notification for your response to my post - I apologize for not replying sooner! I did manage to get the script to work though. Following your instructions in your earlier response to mckoenig, I created a new pdf preset with PDF/X-4:2008 Compatibility / Acrobat (PDF1.4) and named it PSDLayers. I then changed "set myPDFPreset to "[PDF/X-4:2007]" to  "set myPDFPreset to "PSDLayers" in the script. I'm not sure why I couldn't get it working right the first time around, but I've had no problems with it since.  Thanks again for the great script
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 4:12 PM   in reply to anardinelli
    This version should solve the missing PDF preset problems. I've added the dropdown menu with all available PDF presets. PDF/X-4 works best for color management:
    http://www.zenodesign.com/forum/PageToPSLayersCS5v2.zip
    Nov 1, 2011 4:18 PM   in reply to Rob Day
    Thanks so much, but still no luck. The first two layers open in PS, but each one as a seprate document. Then, this error message pops up.Picture 30.png
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 4:37 PM   in reply to anardinelli
    What version of Photoshop are you running?
    Nov 1, 2011 4:40 PM   in reply to Rob Day
    PS5
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 4:47 PM   in reply to anardinelli
    Lets try the log idea. See my post 46. Try a simple document with a couple of layers so the log is short.
    Nov 1, 2011 4:55 PM   in reply to Rob Day
    Sounds good. Here's the log:
    tell application "Adobe Photoshop CS5"
        count every document of current application
    end tell
    tell application "Adobe InDesign CS5"
        activate
            7
        get active document
            document id 7
        get name of document id 7
            "test_1.indd"
        get horizontal measurement units of view preferences of document id 7
            inches
        get vertical measurement units of view preferences of document id 7
            inches
        set horizontal measurement units of view preferences of document id 7 to inches
        set vertical measurement units of view preferences of document id 7 to inches
        get page height of document preferences of document id 7
            11.0
        get page width of document preferences of document id 7
            8.5
        get pages per document of document preferences of document id 7
            1
        choose folder with prompt "Please select the folder you want to save your PDF pages in"
            alias "Macintosh HD:Users:amelia:Desktop:test 1:"
        make with properties {name:"Export to Photoshop"} new dialog
            dialog id 538053
        make new dialog column
            dialog column id 97832 of dialog id 538053
        make new border panel
            border panel id 97833 of dialog column id 97832 of dialog id 538053
            dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make new dialog row
            dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {static label:"Color Mode:"} new static text
            static text id 97836 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {string list:{"RGB", "CMYK", "Lab"}, selected index:0} new dropdown
            dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make new dialog row
            dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {static label:"Page to Export:"} new static text
            static text id 97839 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {edit contents:"1"} new real editbox
            real editbox id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make new dialog row
            dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {static label:"Resolution:"} new static text
            static text id 97842 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {edit contents:"300"} new real editbox
            real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make new dialog row
            dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        make with properties {static label:"Antialias", checked state:false} new checkbox control
            checkbox control id 97845 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        show dialog id 538053
            true
        get selected index of dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
        get edit value of real editbox id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
            1.0
        get edit value of real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
            300.0
        get checked state of checkbox control id 97845 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 538053
            false
        destroy dialog id 538053
        count every layer of document id 7
            3
        get name of every layer of document id 7
            {"Layer 3", "Layer 2", "Layer 1"}
        set visible of every layer of document id 7 to false
        set visible of layer 3 of document id 7 to true
        set page range of PDF export preferences to "1"
        set view PDF of PDF export preferences to false
        export document 1 format PDF type to "Macintosh HD:Users:amelia:Desktop:test 1:13test_1.indd" using PDF export preset "[PDF/X-4:2007]"
            "Adobe InDesign CS5 got an error: Invalid value for parameter 'using' of method 'export'. Expected PDF export preset, but received nothing."
  • Rob Day
    Oct 16, 2007
    Nov 1, 2011 6:14 PM   in reply to anardinelli
    This is from the older version. Try it with the version I just posted in #49— PageToPSLayersV2
    Nov 2, 2011 11:31 AM   in reply to Rob Day
    Hmm, sorry about that. I retried with the version from #49. Here's the error message and the event log. Thanks again for troubel shooting this with me, I really
    appriate it.
    end tell
        activate
            7
        get active document
            document id 7
            "test_1.indd"
            inches
            inches
            11.0
            8.5
            1
        make with properties {name:"Export to Photoshop (PDF/X-4 Preset Recommended)"} new dialog
            dialog id 541119
            dialog column id 97832 of dialog id 541119
            border panel id 97833 of dialog column id 97832 of dialog id 541119
            dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make new dialog row
            dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        get name of every PDF export preset
            {"[High Quality Print]", "[PDF/X-1a:2001]", "[PDF/X-3:2002]", "[PDFX4 2007]", "[PDF/X-4:2008]", "[Press Quality]", "[Smallest File Size]"}
        make with properties {static label:"PDF Preset:"} new static text
            static text id 97836 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make with properties {string list:{"[High Quality Print]", "[PDF/X-1a:2001]", "[PDF/X-3:2002]", "[PDFX4 2007]", "[PDF/X-4:2008]", "[Press Quality]", "[Smallest File Size]"}, selected index:4, min width:250} new dropdown
            dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make new dialog row
            dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            static text id 97839 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make with properties {string list:{"RGB", "CMYK", "Lab"}, selected index:0, min width:250} new dropdown
            dropdown id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make new dialog row
            dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            static text id 97842 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make new dialog row
            dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            static text id 97845 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            real editbox id 97846 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        make new dialog row
            dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            checkbox control id 97848 of dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        show dialog id 541119
            true
        get selected index of dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            4
        get selected index of dropdown id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
        get edit value of real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            1.0
        get edit value of real editbox id 97846 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            300.0
        get checked state of checkbox control id 97848 of dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 541119
            false
        destroy dialog id 541119
            3
        export document 1 format PDF type to "Macintosh HD:Users:amelia:Desktop:test 1:13test_1.indd" using PDF export preset "[PDF/X-4:2008]"
    end tell
        activate
        «event PsCSodoc» file "Macintosh HD:Users:amelia:Desktop:test 1:13test_1.indd" given «class FmOp»:{class:«class cGPF», «class CPrP»:true, «class OMde»:«constant ****e082», «class ResL»:300, «class AnAl»:false, «class crto»:«constant ****crt5»}
            current application
    end tell
        set visible of layer 2 of document id 7 to true
        export document 1 format PDF type to "Macintosh HD:Users:amelia:Desktop:test 1:12test_1.indd" using PDF export preset "[PDF/X-4:2008]"
    end tell
        activate
        «event PsCSodoc» file "Macintosh HD:Users:amelia:Desktop:test 1:12test_1.indd" given «class FmOp»:{class:«class cGPF», «class CPrP»:true, «class OMde»:«constant ****e082», «class ResL»:300, «class AnAl»:false, «class crto»:«constant ****crt5»}
            current application
        get every document
            "Can’t get item 0 of {}."
  • Rob Day
    Oct 16, 2007
    Nov 2, 2011 12:17 PM   in reply to anardinelli
    I can see that it's breaking on the Photoshop PDF open command. Are you running the most recent Photoshop (12.0.4)? What's the version of your OSX? I have not tested the script with Lion.
    Nov 2, 2011 12:28 PM   in reply to Rob Day
    No, I'm running PS 12.0.
    I'm on OS 10.5.8.
  • Rob Day
    Oct 16, 2007
    Nov 2, 2011 12:35 PM   in reply to anardinelli
    Try this version, which uses a different open command:
    http://www.zenodesign.com/forum/PageToPSLayersV3.zip
    Nov 2, 2011 12:53 PM   in reply to Rob Day
    Still no good. See error message and event log.
    end tell
        activate
            9
        get active document
            document id 7
            "test_1.indd"
            inches
            inches
            11.0
            8.5
            1
            alias "Macintosh HD:Users:amelia:Desktop:test 1:untitled folder:"
            dialog id 546806
            dialog column id 97832 of dialog id 546806
            border panel id 97833 of dialog column id 97832 of dialog id 546806
            dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        make new dialog row
            dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            static text id 97836 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        make new dialog row
            dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            static text id 97839 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            dropdown id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        make new dialog row
            dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            static text id 97842 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        make new dialog row
            dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            static text id 97845 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            real editbox id 97846 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        make new dialog row
            dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            checkbox control id 97848 of dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        show dialog id 546806
            true
        get selected index of dropdown id 97837 of dialog row id 97835 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            4
        get selected index of dropdown id 97840 of dialog row id 97838 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
        get edit value of real editbox id 97843 of dialog row id 97841 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            1.0
        get edit value of real editbox id 97846 of dialog row id 97844 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            300.0
        get checked state of checkbox control id 97848 of dialog row id 97847 of dialog column id 97834 of border panel id 97833 of dialog column id 97832 of dialog id 546806
            false
        destroy dialog id 546806
            3
        export document 1 format PDF type to "Macintosh HD:Users:amelia:Desktop:test 1:untitled folder:13test_1.indd" using PDF export preset "[PDF/X-4:2008]"
    end tell
        activate
        «event PsCSodoc» alias "Macintosh HD:Users:amelia:Desktop:test 1:untitled folder:13test_1.indd" given «class FmOp»:{class:«class cGPF», «class CPrP»:true, «class OMde»:«constant ****e082», «class ResL»:300, «class AnAl»:false, «class crto»:«constant ****crt5»}
            current application
    end tell
        export document 1 format PDF type to "Macintosh HD:Users:amelia:Desktop:test 1:untitled folder:12test_1.indd" using PDF export preset "[PDF/X-4:2008]"
    end tell
        activate
        «event PsCSodoc» alias "Macintosh HD:Users:amelia:Desktop:test 1:untitled folder:12test_1.indd" given «class FmOp»:{class:«class cGPF», «class CPrP»:true, «class OMde»:«constant ****e082», «class ResL»:300, «class AnAl»:false, «class crto»:«constant ****crt5»}
            current application
        get every document
  • Rob Day
    Oct 16, 2007
    Nov 2, 2011 1:19 PM   in reply to anardinelli
    Try updating to the most recent 12.0.4. I don't think there was full scripting support in 12.0.
    http://www.adobe.com/support/downloads/product.jsp?product=39&platform =Macintosh
    Nov 2, 2011 1:36 PM   in reply to Rob Day
    Rob, that did the trick! I can't thank you enough for your patience and
    perseverance. The script works beautifully. Bravo!
  • Rob Day
    Oct 16, 2007
    Nov 2, 2011 2:17 PM   in reply to anardinelli
    Your welcome. I'll update the read me so users know about the 12.0 problem.
    Nov 21, 2011 5:59 PM   in reply to Rob Day
    hello rob,
    I have stupidly used indesign to create this whole website layout, so now i need to export it to photoshop for the web guy to code....
    Thank you for the script, it is fantastic! - the answer to my prayers (...nearly)
         it's just, with the script you've provided, it exports all the layers and flattens all my sub-layers/items in those layers.
         .... say i've created a navigation bar, and i've group all the items into one big layer, it gets flattened when exported...
    I know i've dug my own hole, and should probably just make the items into layers, but it will take too long and there's so many pages...
    do you happen to have a solution? or did i just confuse you more?
    thanks!
  • Rob Day
    Oct 16, 2007
    Nov 22, 2011 6:46 AM   in reply to on_a_slant
    It would be possible to script but it wouldn't be trivial, you'd have to consider groups, inline graphics, and maybe Photoshop's total layer limit.
    Dec 27, 2011 7:33 AM   in reply to Rob Day
    Rob, great script. An extra Christmas present as I'm in need of creating layered PS files of quite number of InD files that I've already created for a client who is now demanding PS instead of InD.
    The only thing that I'm trying to get in the PS now is the crop marks and a bleed of .125". I've made a PDF preset that is such and I select that preset once the dialogue box comes up when the script is activated. But, I don't get either the bleed or crop marks in the final PS document.
    If you have any suggestions, I'd REALLY appreciate it.
    Rick
    Dec 27, 2011 8:12 AM   in reply to RJensenArtDirector
    Rob,
    I just did a work-around  by changing the size of my InD document to include the bleed and then have added guides in PS for client reference.
    Thanks again for the great script — it's working flawlessly.
    Rick
  • Rob Day
    Oct 16, 2007
    Dec 27, 2011 8:34 AM   in reply to RJensenArtDirector
    I'm traveling, the script sets the PDF bounds to the trim, but it could include crops. I'll post something later today.
    Dec 27, 2011 12:45 PM   in reply to Rob Day
    Rob,
    Thank you for your quick reply. First of all, thanks for the super time saving script. It's working great.
    I've done a work around by changing the InD document size to include the .125 of bleed I need and then in PS I'm adding the guides for the client reference. So, thank you and whenever you get around to it — I'd certainly take the updated script the next time I need to do this.
    Who wants a layout in PS anyway? Dang clients.
    Thanks Rob.
    Rick
  • Rob Day
    Oct 16, 2007
    Dec 27, 2011 11:24 AM   in reply to RJensenArtDirector
    You don't mean this is a print job? Hope you're getting paid up front.
    To include the PDF preset's crops you need to edit the script. Look for the 3 lines where the crop page is set to trim box and change to bounding box.
    So this:
    if colorMode is "CMYK" then
              set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:CMYK, resolution:res, use antialias:aa, crop page:trim box}
                   else
              if colorMode is "RGB" then
                    set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:RGB, resolution:res, use antialias:aa, crop page:trim box}
                        else
                   if colorMode is "Lab" then
                        set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:Lab, resolution:res, use antialias:aa, crop page:trim box}
                   end if
              end if
    end if
    Needs to be:
              set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:CMYK, resolution:res, use antialias:aa, crop page:bounding box}
                   else
                    set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:RGB, resolution:res, use antialias:aa, crop page:bounding box}
                        else
                        set myOpenOptions to {class:PDF open options, constrain proportions:true, mode:Lab, resolution:res, use antialias:aa, crop page:bounding box}
                   end if
              end if
    end if
    Dec 27, 2011 12:40 PM   in reply to Rob Day
    Hey Rob.
    Yeah, this is a print job! Crazy. He's got InDesign too!
    We're past being billable on this one.
    Thanks for the edit to the script.
  • John Hawkinson
    Jun 25, 2009
    Dec 27, 2011 12:37 PM   in reply to RJensenArtDirector
    FYI, Rick, your email address and phone number appear in all your posts via email for all the world to see -- you should suppress your signature when replying via email. You should be able to edit it out of at least the last few posts on the web interface as well (but a moderator might have to do some).
    Dec 27, 2011 12:42 PM   in reply to John Hawkinson
    John,
    A huge thanks for that one. I didn't realize that the reply was feeding back into the forum post.
    Thanks man.
    Dec 27, 2011 12:46 PM   in reply to RJensenArtDirector
    I deleted it from the other one.
    Bob
    Dec 27, 2011 12:47 PM   in reply to Bob Levine
    Thank you Bob.
    Jan 18, 2012 4:37 AM   in reply to Arjan_Scholten_Muntz-MCG
    Funny how things go in this world.
    I work for a prepress company in the Netherlands (so forgive my bad english!).
    A collega comes to me with the question if its possible to export an InDesign document with layers to a Photoshop document with layers.
    I am not sure about this and start looking on the world wide web.
    And.. find a solution or not...
    Because the link to PageToPSLayersCS5v2.zip or ...v3.zip or all dead.
    It redirect back to this Adobe Forums site.
    So my question is now: does it work and where can I find it.
    (working with Photoshop 12.04 x64, InDesign 7.0.1 and Mac OS X 10.6.8)
    Maybe it's a stuppid question but better ask it than keep looking for mayby nothing.
    In all cases thanks anyway.
    Ray
  • Rob Day
    Oct 16, 2007
    Jan 18, 2012 5:05 AM   in reply to RBA2000
    I just checked this link and it works
    Jan 18, 2012 5:29 AM   in reply to Arjan_Scholten_Muntz-MCG
    InDesign to Photoshop Layers
    File>Export>PDF> Acrobat 6 or above and Create Layers
    Open PDF in Illustrator
    File>Export>PSD and select write layers
    Tried it on a fairly complex page with text, blending modes, etc. all layers came thorough fine, with clipping masks and all in tact.
  • Rob Day
    Oct 16, 2007
    Jan 18, 2012 9:26 AM   in reply to Eugene Tyson
    Eugene, Are you getting your ID named layers into AI?
    I get one layer (Layer 1) in AI with all of the ID objects as layer objects, which might be good depending on what your looking for. In my test file a column of text is cut up into lines with each on its own layer—the script would export the two user defined layers. The AI approach is definitely better if you want every object on its own layer.
    ID
    AI
Actions
Bookmarked By (1)
