we are currently implementing a custom check-in dialog for Bridge.
The dialog contains a Combobox.
The available items in the combobox are loaded from a web-service, called from Bridge. How is it possible to provide the Flex UI with data from Bridge?
I think I'm on the right track but I'm not able to get it working.
I'm using the IGetCustomCheckInUIContextInfoHandler from the Drive SDK, and have added following testcode:
HashMap<String, Object> items = new HashMap<String, Object>();
items.put("key1", "value1");
items.put("key2", "value2");
response.setContextInfo(items);
In the Flex Mdule, I have implemented ICustomCheckInUI and using following code:
public function setContextInfo(info:Object):void
var items:Array = info as Array;
if(items != null) { workflowCombo.dataProvider = items; } }
When running, I am able to see the ComboBox, but it is empty. Anyone an idea?
for the setContextInfo() function, you should write it like the below:
if(info == null)
return
var items:Array = new Array();
if (info.hasOwnProperty("key1"))
items["key1"] = info["key1"];
if (info.hasOwnProperty("key2"))
items["key2"] = info["key2"];
The context info object sent from your Java connector will be wrapped into a generic Flex Object class instance, all the keys will become its properties, all the values will become property values. you cannot cast it directly into an Array instance. Thanks Gang
Thanks for your reply.
But I think theres another problem we're facing.
When I add the following line in setContextInfo(), my custom module is not visible in the check-in dialog, even if 'items' is a simple array.
var items:Array = ["A", "B"];
If I remove the line
my module is available in the check in dialog (but is empty of course).
Is there a way to have some logging?
Could the problem be that binding the combobox at this time is too late?
Sorry for late response.
There are two reasons causing your problems.
1) It's too early to bind Combobox in the SetContextInfo() function, SetContextInfo() function is called by AdobeDrive in the ModuleLoader.ready Module Event handler, during this time, the creation of Combobox is not finished, you should simply preserve the context info passed to you in SetContextInfo(), then bind Combobox with it in its creation complete event handler.
2) The dataprovider of ComboBox should be an ICollectionView instance, Array class doesn't meet this requirement
The sample code is as follows:
protected function module1_creationCompleteHandler(event:FlexEvent):void
if (_contextInfo == null)
return;
var items:ArrayCollection = new ArrayCollection();
items.addItem("value1");
items.addItem("value2");
testCombo.dataProvider = items;
thanks a lot for your help. This is working now.
One last issue however. Following code fragment (in the Flex code)
public function getInteractionResults(): Object
return null;
when I'm returning 'null' it works, meaning that I am able to cllick the OK button of the checkin dialog and checkin continues.
But when I'm trying to return something else, clicking the OK button does not do anything at all: the dialog stays open.
I need to return the selected item of the comboBox. In the documentation I have read that the object you are returning must be an associative array.
When trying something like following line, again the OK button does not respond:
var returnValue:Array = new Array();
returnValue["key"] = "value";
return returnValue;
Again many thanks in advance.
I tried to reproduce the issue with your code on my side, however everything was fine, the source code is attached below, please try it
<?xml version="1.0" encoding="utf-8"?>
<mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400"
height="100" implements="com.adobe.drive.customui.moduleinterface.ICustomCheckInUI" creationComplete="module1_creationCompleteHandler(event)">
<mx:Script>
<![CDATA[
import com.adobe.drive.customui.moduleinterface.ICustomCheckInUI;
import mx.events.FlexEvent;
import mx.collections.ArrayCollection;
private var _contextInfo:Object;
public function setLocale(locale:String):void
return;
_contextInfo = info;
public function getWidth():int
return 400;
public function getHeight():int
return 100;
public function getInteractionResults():Object
returnValue[key] = value;
return returnValue;
return;
if (_contextInfo.hasOwnProperty(defaultValue))
this.TestPropertyValue.text = _contextInfo[defaultValue];
items.addItem(value1);
items.addItem(value2);
</mx:Script>
<mx:Canvas width="100%" height="100%" borderStyle="inset">
<mx:Label id="TestPropertyName" x="32" y="37" text="TestProperty:" width="100"/>
<mx:TextInput id="TestPropertyValue" x="195" y="35" width="164"/>
<mx:ComboBox id="testCombo" x="32" y="64"></mx:ComboBox>
</mx:Canvas>
</mx:Module>
No, on my side, requestItem.getCustomParameters() returns the correct interaction result
item CheckInRequest$Item (id=212)
content InputStreamReadableByteChannel (id=214)
contentSize 109753
customParameters CustomParameters (id=219)
parameter HashMap<K,V> (id=223)
entrySet HashMap$EntrySet (id=231)
keySet null
loadFactor 0.75
modCount 1
size 1
table HashMap$Entry<K,V>[16] (id=224)
[0] null
[1] null
[2] null
[3] null
[4] null
[5] null
[6] null
[7] null
[8] null
[9] null
[10] null
[11] null
[12] null
[13] null
[14] null
[15] HashMap$Entry<K,V> (id=225)
hash -922089969
key "key" (id=143)
next null
value "value" (id=144)
threshold 12
values null
identity RemoteAssetIdentity (id=221)
lockToken null
mimeType null
modificationDate 1307635200000
replace false
versionProperties null
xmp null
Please do the following steps to re-test your connector
1) unmount all the drives
2) kill CS5ServiceManager
3) make sure getInteractionResults() in the Flex part return the correct value
4) Compile you Flex module and replace the old one
5) re-connect your server
This is what I got,
, I still can not reproduce your issue
item CheckInRequest$Item (id=593)
content InputStreamReadableByteChannel (id=596)
contentSize 75579
customParameters CustomParameters (id=597)
parameter HashMap<K,V> (id=598)
entrySet HashMap$EntrySet (id=666)
keySet null
loadFactor 0.75
modCount 1
size 1
table HashMap$Entry<K,V>[16] (id=599)
[0] null
[1] null
[2] null
[3] null
[4] null
[5] null
[6] null
[7] null
[8] null
[9] null
[10] null
[11] null
[12] null
[13] HashMap$Entry<K,V> (id=602)
hash -199977139
key "myKey" (id=584)
next null
value "myValue" (id=585)
[14] null
[15] null
threshold 12
values null
identity RemoteAssetIdentity (id=594)
lockToken null
mimeType null
modificationDate 1307894400000
replace false
xmp null
MXML file, could you totally use this file for your test and see what happens?
<mx:Script>
<![CDATA[
return;
return 400;
return 100;
var key:String = myKey;
var value:String = myValue;
return returnValue;
return;
</mx:Script>
</mx:Canvas>
</mx:Module>
It's really strange, if you don't mind, can you share you whole Flex project with me? you can zip it and send it to gzheng@adobe.com, I will compare your project setting with mine and test it with BR5.5
I think we have found the issue now.
Using Bridge:
- do checkout - edit file - checkin: getCustomParameters() is working correctly.
- add a new file to bridge (which is automatically checked in) : the getCustomParameters() method returns null.
Can you please verify that adding a new file using Bridge is really the issue here?
Yes, there is an issue here in adding a new file using Bridge, the main reason is, it's hard to extract the server information at that time, we will find out how to correct it in the future releases, a bug will be logged.
please recommend your users to copy the file into AD file system using Explorer/Finder first, the file status is new, then use Bridge to check-in it.
Thanks for reporting it.
Gang
