I want to put stroke just 2 or 3 sides of a picture in Indesign CS5 . Is this possible ?
Thank you
Sure. Just place your picture, and then with the picture selected, use the scissor tool (in the tool box) and click on two of the corner handles. Using the direct-select tool (white arrow) select the segment between the two handles you cut, and delete. now you can select the picture again, and give it any type of stroke you want.
Hope that helps.
Cheers!
-Mikey
Are you sure about that, Mikey?
In my experience you can remove one side of a frame and it will continue to show uncropped content as if the side were still there, but if you try to remove tow adjacent sides you will have a triangular crop using an invisible line joining the remaining endpoints, and removing opposites sides doesn't work at all, so if you want a troke on two sides you need to creat that separately form the frame holding the image, then group.
I use it most often with one side when I have footnotes in a separate
frame (when I can't use InDesign's native footnotes). I use it as the
rule above.
You can control which sides the stroke starts at by drawing the frame
with the pen tool. The side you start drawing is where the stroke style
starts at.
