microwebber
Flash Component swc and components panel question
Sep 21, 2011 1:31 PM
EDIT:
I did not use the mxi file to install the component.  Now it is installed, but within my directory it shows 2 more components.  The List, and Label component are there.
I thought only my component would be there.  Should I delete these from my the library?
I tried deleting them.  That was a bad idea.
Should I just leave them?
Is that the way extended components show in the components panel?
I'm creating a tree component for as3.  I've followed the instructions on this page, up to 9
http://www.adobe.com/devnet/flash/articles/creating_as3_components_pt9 .html
And it works if I drag the comonent from my component file to any file I want to use it in.
But it doesn't work if I try to export the component as a swc to the same directory, then copy that swc to the User Interface directory.
I refresh the component panel,  and it appears, but when I drag it from the components panel to a new file, the assets are not imported.
Only the component itself.
Do I need to install the fla somewhere?
