JavaScript how to use body unload with Content Management Systems like Wordpress?
Jul 29, 2011 9:33 AM
I'm using Wordpress and I'm stuck with a javascript that uses body onload to work. I'm not very familiar with javascript.
Any suggestions on how to implement javascript within CMS when using body onload?
Here is the script
var SLIDETIMER = 3;
var SLIDESPEED = 1;
var SCROLLTIMER = 3;
var SCROLLSPEED = 1;
var STARTINGOPACITY = 40;
// handles section to section scrolling of the content //
function slideContent(id,prefix,timer) {
  var div = document.getElementById(id);
  var slider = div.parentNode;
  clearInterval(slider.timer);
  slider.section = parseInt(id.replace(/\D/g,''));
  slider.target = div.offsetTop;
  slider.style.top = slider.style.top || '0px';
  slider.current = slider.style.top.replace('px','');
  slider.direction = (Math.abs(slider.current) > slider.target) ? 1 : -1;
  slider.style.opacity = STARTINGOPACITY * 1;
  slider.style.filter = 'alpha(opacity=' + STARTINGOPACITY + ')';
  slider.timer = setInterval( function() { slideAnimate(slider,prefix,timer) }, SLIDETIMER);
function slideAnimate(slider,prefix,timer) {
  var curr = Math.abs(slider.current);
  var tar = Math.abs(slider.target);
  var dir = slider.direction;
  if((tar - curr <= SLIDESPEED && dir == -1) || (curr - tar <= SLIDESPEED && dir == 1)) {
    slider.style.top = (slider.target * -1) + 'px';
     slider.style.opacity = 1;
     slider.style.filter = 'alpha(opacity=100)';
     if(slider.autoscroll) {
       setTimeout( function() { autoScroll(slider.id,prefix,timer) }, timer * 1000);
  } else {
     var pos = (dir == 1) ? parseInt(slider.current) + SLIDESPEED : slider.current - SLIDESPEED;
    slider.current = pos;
    slider.style.top = pos + 'px';
// handles manual scrolling of the content //
function scrollContent(id,dir) {
  clearInterval(div.timer);
  var sections = div.getElementsByTagName('div');
  var length = sections.length;
  var limit;
  if(dir == -1) {
    limit = 0;
  } else {
    if(length > 1) {
      limit = sections[length-1].offsetTop;
    } else {
      limit = sections[length-1].offsetHeight - div.parentNode.offsetHeight + 20;
  div.style.opacity = STARTINGOPACITY * 1;
  div.style.filter = 'alpha(opacity=' + STARTINGOPACITY + ')';
  div.timer = setInterval( function() { scrollAnimate(div,dir,limit) }, SCROLLTIMER);
function scrollAnimate(div,dir,limit) {
  div.style.top = div.style.top || '0px';
  var top = div.style.top.replace('px','');
  if(dir == 1) {
     if(limit - Math.abs(top) <= SCROLLSPEED) {
       cancelScroll(div.id);
       div.style.top = '-' + limit + 'px';
     } else {
       div.style.top = top - SCROLLSPEED + 'px';
  } else {
     if(Math.abs(top) - limit <= SCROLLSPEED) {
       div.style.top = limit + 'px';
     } else {
       div.style.top = parseInt(top) + SCROLLSPEED + 'px';
// cancel the scrolling on mouseout //
function cancelScroll(id) {
  div.style.opacity = 1;
  div.style.filter = 'alpha(opacity=100)';
  clearTimeout(div.timer);
// initiate auto scrolling //
function autoScroll(id,prefix,timer,restart) {
  div.autoscroll = (!div.autoscroll && !restart) ? false : true;
  if(div.autoscroll) {
    div.section = (div.section && div.section < length) ? div.section + 1 : 1;
    slideContent(prefix + '-' + div.section,prefix,timer);
// cancel automatic scrolling //
function cancelAutoScroll(id) {
  div.autoscroll = false;
I tried using this within the head tags, but it didn't work:
<script type="text/javascript" src="http://www.theperfectknotsd.com/wp-content/themes/theperfectknot/js/sl ider.js"></script>
<script type="text/javascript">
autoScroll('newsslider','newssection',5,true);
//--></script>
How other are using javascripts that require body onload within Content Management Systems? I just don't get it, I've tried different techniques suggested from other blogs and no luck at all.
    Sep 21, 2011 11:32 PM   in reply to pchinique
    It should be perfectly fine to include it in head - depending on wha you want.
    Try to use Firebug for firefox to debug errors.
    You can add plugins to wordpress that makes it easier to include scripts.
