Coloring a Font with a RGB etc. without adding the color to the document swatches.
Sep 21, 2011 3:50 PM
Is there a way of coloring a font with a RGB, Lab or CMYK color without adding the color to the document swatches.
The only way I know is to add a color to the swatches or use one that already exists.
like
   app.selection[0].characters[0].fillColor=document.colors.add({colorVa lue: [255, 53, 160], space: ColorSpace.RGB});}
This has the undesired effect of cluttering up the swatches when using a lot of colors.
any ideas?
  • John Hawkinson
    Jun 25, 2009
    Sep 21, 2011 9:58 PM   in reply to Trevorׅ
    InDesign Tagged Text?
    In short: no, not really, seems like a limitation.
    Sep 22, 2011 12:19 AM   in reply to Trevorׅ
    Using standard methods, the only way to add colors is by adding a swatch.
    If you have an unnamed color in your document, you can apply it to another object using obj1.fillColor = obj2.fillColor.
    So, if you can get the unnamed color in your document somehow, you can apply it via scripting.
    One way to do that would be to write a snippet programmatically with the desired color, import that, apply the color and remove the placed snippet.
    You can check if the color exists already in the doc before doing that...
    Harbs
  • John Hawkinson
    Jun 25, 2009
    Sep 22, 2011 12:27 AM   in reply to Harbs.
    Definitely easier with InDesign Tagged Text:
    <ASCII-MAC>
    color test
    <cColor:COLOR\:CMYK\:Process\:0.75\,0.5\,0.53\,0.10>seventy<cColor:>
    nocolor test
    Sep 22, 2011 12:38 AM   in reply to John Hawkinson
    Good idea.
    Sep 22, 2011 7:07 AM   in reply to Trevorׅ
    Okay...
    Here's a multi-purpose function which takes an array of three or four values and returns an unnamed color (either RGB or CMYK) using the methods we discussed here:
    function GetUnnamedColor(values){
        if( !(values instanceof Array) ){
            throw("Values must be an array of three or four values");
        var fileString = "<ASCII-MAC>\r" +
            "<pstyle:><cc:COLOR\:";
        if(values.length == 3){
            fileString = fileString + "RGB\:Process\:";
            for(var i=0;i<values.length;i++){
                values[i] = values[i]/255 * 100;
        else if(values.length == 4){
            fileString = fileString + "CMYK\:Process\:";
        else {
            if(values[i] >= 100){
                fileString = fileString + "1";
            } else {
                values[i] = values[i].toString();
                var tempSplit = values[i].split(".");
                while(tempSplit[0].length<2){
                    tempSplit[0] = "0" + tempSplit[0];
                values[i] = tempSplit.join("");
                fileString = fileString + "0."+values[i];
            if(i<values.length-1){
                fileString = fileString + "\,";
        fileString = fileString + ">Just Some Text<cc:>";
        var file = File(Folder.temp+"color_import.txt");
        file.open('w');
        file.write(fileString);
        file.close();
        var story = app.documents[0].pages[0].place(file)[0];
        var color = story.fillColor;
        story.textContainers[0].remove();
        return color;
    alert(GetUnnamedColor([75,0.5,53,10]).colorValue);
    Harbs
    [Edit] It assumes a document to be open. I have real work to do, so I can't make it more robust right now...
    Dec 9, 2011 4:55 PM   in reply to Trevorׅ
    Gosh I have no idea what prompted me to visit this thread again
    ... Here is a one-liner to set the color of a text selection to any RGB, Lab, or CMYK color without adding it to the Swatches list:
    app.selection[0].fillColor.properties = {space:ColorSpace.RGB,colorValue:[255,255,0]};
    Impressed? Well, if you try it you'll notice it won't work straight away. There Is A Catch! (Two of 'em, actually.)
    (spoiler space)
    Catch #1: You can only change the color of text if it already has an 'undefined' color!
    Now usually, you'll find your text already comes with a swatch applied to it, even though it's simply "Black", and so you cannot use this trick. If you do want to use it, you have to change it first to the fillColor of a text that already has an undefined color applied to it; then you can change it to anything you want. But you cannot create a piece of text to act as model to begin with, using a script (well, other than Harbs' workaround with a temporary snippet file) -- a real Catch-22.
    To get it to work, draw a new text frame somewhere on the pasteboard in your document and enter this text into it: "A Jongware Solution". (Use exactly this text.) Change the color to something random, using the Color panel. Use the Script Label panel to add a label to the text frame -- use "color placeholder". Then, just before the line that sets other text to any color, insert this:
    app.selection[0].fillColor = app.activeDocument.textFrames.item("color placeholder").characters[0].fillColor;
    At first glance, this appears to work, but I noticed The Weirdest Thing. If you apply this color to your newly selected text, you'll find it initially is set to the placeholder color. That's to be expected. The second line (the one at the top of this post) also works, as you will see the color change to the new settings.
    However. Catch #2
    Check what happens to the placeholder text ... It also changes its color! Curioser & curioser, if you used this trick a couple of times in the same document, you'll find that every item with the same color also changes! It's kinda like ... you have a swatch ... but not really ...
    Dec 11, 2011 3:56 AM   in reply to Trevorׅ
    I'm afraid it's not that straightforward. "Delete Swatch" is a menu option but "Replace with Unnamed Color" is not, so there is nothing to invoke.
    Mar 8, 2012 8:15 AM   in reply to Harbs.
    Hi all, I am trying to accomplish the same goal (except color a textFrame not text) and I am using Harbs method but am only getting black boxes.
    var r=0;
    var g=102;
    var b=255;
    var elemBox = currentPage.textFrames.add(); //Add box
    var addedColor = GetUnnamedColor([r,g,b]);
    elemBox.fillColor = addedColor;
    The filestring that gets written to the temp. file is:
    <ASCII-MAC>
    <pstyle:><cc:COLOR:RGB:Process:0.00,0.40,1>Just Some Text<cc:>
    the addedColor.colorValue is 0,0,0,100
    Is anyone else experiencing the same results?
    Mar 8, 2012 9:27 AM   in reply to bduffy323
    I get the expected results—addedColor.colorValue is [0,102,255]—in CS5 and CS4 on the Mac. I don't have any good theories about why you're seeing what you're seeing. Have you tried with a fresh document or after trashing or temporarily moving your prefs and defaults?
    Jeff
    Mar 8, 2012 10:53 AM   in reply to bduffy323
    You input RGB and you get *four* values in return...?
    Mar 8, 2012 11:02 AM   in reply to [Jongware]
    @Jongware - Yes that is correct. I copied the function verbatum and that is what I get in return. I Have also tried putting in dummy values for a CMYK [50,50,20,0] and I get the same result.
    @absqua - I am running CS5.5 on a PC. Does that effect the <ASCII-MAC> maybe?
    Mar 8, 2012 11:21 AM   in reply to bduffy323
    You saw this same problem before, without using Harbs's function, right? (Your other thread?) So I don't think it has anything to do with the tagged text. I know it seems like grasping at straws, but, in the absence of any other ideas, can you try clearing your defaults and starting with a new document?
    Mar 8, 2012 11:25 AM   in reply to absqua
    Well, my other thread is a similiar problem and I'm hoping that this solution is a work-around for that (since I was grasping at straws over there as well). I'm actually using an entirely new document (created by script) and am adding rectangles that each have a color assigned to them. So it works using:
    var addedColor = myDoc.colors.add({space:ColorSpace.RGB,colorValue:[r,g,b]});
    It just adds them all to the swatches fly-out which I need to avoid as well. So I'm hoping by finding a solution to this problem, it will also solve my other threads problem which is slightly different. Fingers crossed.
    Mar 8, 2012 12:12 PM   in reply to bduffy323
    Ah the solution! After researching tagged text, I found that on a windows platform you must have <ASCII-WIN>. The colors come through as expected. I will post on my other thread if this solution works to solve that as well.  Except I wont be able to test that until tomorrow.
    Just on more question. Harbs says above that "You can check if the color exists already in the doc before doing that..." and by that he means executing that method. But how do you check for the unnamed color?
    Message was edited by: bduffy323
