I'm trying to include two source folders, both named src - my Flash Builder project only allows one - doesn't show the second. One reference uses an absolute path on an external drive to my source and the other a relative path to the fl.motion classes. I can rename my source folder but it's referenced in a lot of projects and I was hoping there was another solution.
You can add a linked folder with different name for your external source. Go to File->New->File. Click 'Advanced' and provde linked folder location. Enter name of the folder as 'srcMotion' and click Finish. Now add 'srcMotion' in source path.
Thanks for the reply. I was able to accomplish the result based on your directions. There were a few minor things I had to adjust:
- File->New->File should read File->New->Folder
- also, I discovered when adding the new virtual folder to the source path there is no GUI file dialog to find and pick it - it requires that you enter the new file name.
However, great advice and thanks for the solve.
Chris
