alienA2
Javascript/ Batch Processing - Query (Please assist/advice)
Sep 19, 2011 11:23 PM
Hi
Where can I find on the internet a JavaScript that will do the following for BATCH PROCESSING:
-Combine single PDF files
-Crop the pages
-Check the sequence of the pages that it goes from 1,2,3 and so on
-ad metadata to the PDF
-set view
-add bookmarks based on the content page's major headings (e.g. Regulars)
-Making single PDF files over 1.5 MB smaller
-Fix white lines
-Make the final file as a PDF that is compatible with Acrobat 5 or later
Replies 1 2 Previous Next
    Sep 20, 2011 12:14 AM   in reply to alienA2
    You're mixing and matching different things here.
    First of all, a batch process is meant to process each file in the same way. It can't combine single PDF files for you.
    What you can do is use a batch process to collect the paths of the files, and then combine them later on with a script.
    For example, this tool (created by me) uses a batch sequence to collect the file paths and then combines all files in the same folder:
    http://try67.blogspot.com/2010/10/acrobat-batch-combine-all-files-in.h tml
    After you have your combined file(s) you can indeed use a batch process to do most of what you asked for, whether with a script or one of the built-in commands.
    Some things I'm not sure you can do at all (like "fix white lines"... what do you mean by that?, or to add bookmarks based on the page's content).
    Sep 20, 2011 1:22 AM   in reply to alienA2
    The problem is not creating a bookmark with a script (read about the Bookmark object and its createChild() method in the Acrobat JS Reference).
    The problem is identifying the text you want to use for that bookmark.
    The only way I can see this being possible is if this text is always in the same coordinates on the page (more or less), or if it's always the laregest text on the page. Both of these options require quite a complex script to identify this text, though.
    Sep 20, 2011 3:15 AM   in reply to alienA2
    That's quite easy to do, using the method I've mentioned before.
    Sep 20, 2011 4:14 AM   in reply to alienA2
    Do you mean an example? Yes, in the reference file.
    Here's an example I sent recently to someone on a different forum:
    This code will create 3 bookmarks that go to pages 1 to 3:
    1. this.bookmarkRoot.createChild({cName:"Page 1", cExpr:"this.pageNum = 0", nIndex: 0})
    2. this.bookmarkRoot.createChild({cName:"Page 2", cExpr:"this.pageNum = 1", nIndex: 1})
    3. this.bookmarkRoot.createChild({cName:"Page 3", cExpr:"this.pageNum = 2", nIndex: 2})
    Sep 20, 2011 4:35 AM   in reply to alienA2
    Look at the various actions that are available to you when you create a new batch sequence. You can do most on the items on that list using those actions.
    Sep 20, 2011 5:35 AM   in reply to alienA2
    I'm not following you... What do you mean, exactly?
    Sep 20, 2011 6:55 AM   in reply to alienA2
    this.bookmarkRoot.createChild({cName:"Front Cover", cExpr:"this.pageNum = 0"})
    this.bookmarkRoot.createChild({cName:"Back Cover", cExpr:"this.pageNum = this.numPages-1"})
    Sep 21, 2011 5:04 AM   in reply to alienA2
    Can it identify text with a certain color, and/or font style?
    No.
    Is it able to select the number of the heading and use that number as the set destination?
    No.
    I would like to delete the existing bookmarks first then add my own bookmarks. How do i do this?
    Use the method remove() of the Bookmark object.
    Sep 21, 2011 10:41 AM   in reply to alienA2
    I assume you referring to this.bookmarkRoot.remove();
    Well, this.bookmarkRoot.remove() will remove all the bookmarks, but the remove() method can also be used to remove specific bookmarks.
    1. Execute a plug-in software, which I have installed to use inside Acrobat, to run inside Adobe Acrobat Pro?
    I don't think so. The other way around (plugin executing JS code) is possible, though.
    2. Extract seperate pdf pages from 1 to the end of the Pdf file and place them in a specific folder.
    Yes. See the extractPages() method of the Document object.
    where could I find the batch sequences which I have created in the Acrobat directory folder?
    Acrobat has two folders for batch sequences, one for system ones and one for user-defined ones. You can find out what the user-defined path is on your machine by executing the following code from the console:
    app.getPath("user","sequences")
    Sep 22, 2011 5:17 AM   in reply to alienA2
    Then call it multiple times, each time for each page number you want to
    extract (using different file names, obviously).
    Did you execute it using Ctrl+Enter?
    Sep 23, 2011 12:27 AM   in reply to alienA2
    You need to specify the cPath parameter with a unique file name (you can use
    the value of the iterator i in the file name)...
    Sep 23, 2011 1:18 AM   in reply to alienA2
    Almost. The path needs to have the correct syntax used by Acrobat JS for
    files, and must also end with ".pdf", so something like this:
    cPath: "/c/extr/page" + 1 + ".pdf"
    (I'm assuming here you're running this code from a batch process. If not,
    you'll need to place the entire thing in a trusted function, as is explained
    in the Reference)
    Also, when you extract a page it is not automatically opened, so there's no
    need to close it.
    Sep 24, 2011 10:11 AM   in reply to alienA2
    You need to use some kind of unique identifier in the filename, for example
    you can use the original file name or define some kind of global counter
    that you increment after each save.
    Sep 25, 2011 2:03 AM   in reply to alienA2
    this.documentFileName
    Sep 25, 2011 2:40 AM   in reply to alienA2
    I don't really understand. documentFileName returns just the file name
    (including the extension).
    If you don't want the full file name there are various options of editing
    it, like with a regular expression or with the various methods of the String
    object. You'll need to define what it is, exactly, that you want to do,
    though.
    Sep 25, 2011 7:01 AM   in reply to alienA2
    this.documentFileName.replace(/\.pdf$/i,"")
    Oct 4, 2011 12:35 AM   in reply to alienA2
    In the batch process script, you can use something like this:
    if (/apple/.test(this.documentFileName)) {
         // then add the "apple" bookmark
    } else if (/banana/.test(this.documentFileName)) {
       // then add the "banana" bookmark
    etc.
    Oct 4, 2011 1:12 AM   in reply to alienA2
    If you want, you can contact me by email: try6767 at gmail dot com.
1 2 Previous Next
Actions
