How to inspect Adobe Drive requests using Fiddler or similar tool?
Jul 22, 2011 2:09 AM
I have added our DAM server as a network drive using Adobe Drive. I need to capture and inspect the requests sent by Adobe Drive to my DAM server. Can I do this using Fiddler or Wireshark or any similar tool?
I have read Fiddler help which gives steps to configure applications to use Fiddler. But I am not able to figure out how to do that with Drive.
For the testing purposes, both Drive and the server are installed on local machine. But I do make request with http://machinename instead of localhost.
The reason I want to do this is some operations like 'check out' selected from Drive menu, does not hit my code at all. I want to check the discrepancies that's causing this.
Any help is greatly appreciated.
    Jul 22, 2011 2:10 AM   in reply to mandarpkulkarni@gmail.com
    Hallo,
    ich bin am 25. Juli 2011 wieder im Büro und werde Ihre Mail dann beantworten. In dringenden Fällen wenden Sie sich bitte an unser Büro unter +43 1 9902 804 oder office@metamagix.net.
    Mit freundlichen Grüßen,
    Martin Gilly.
    Hello,
    I will be in the office again on July 25th and will then take care of your mail. In urgent cases, please contact our office @ +43 1 9902 804 or office@metamagix.net.
    Kind Regards,
    Martin Gilly.
    Sep 20, 2011 9:56 PM   in reply to mandarpkulkarni@gmail.com
    I have the same question.  How can Adobe Drive 3 be configured to use a HTTP proxy server?   I don't see proxy host and port fields in Drive > Settings, and  Windows Server 2008 > Control Panel > Internet Options > .... LAN settings > use proxy > 127.0.0.1 : 8888  did not work.   Thank you.
    Sep 26, 2011 4:18 AM   in reply to cmis123456
    Adobe Drive 3 can't be configured to use a HTTP proxy server now. We'll add this support in future.
    For your case, I suggest you to try "Using Fiddler as a Reverse Proxy".
