I am new to Premiere. Just purchased and installed CS5. I will be doing a lot of hand holding of the camera with nature and need a good stabilizer program. I found one called ProDad that looks good but not yet working on CS5. They say it will be release the end of this month and if so that may be a good solution. But there must be more to compare.
Anyone know of another solution. I am just not steady enough to hand hold the camera and not fix it.
Thanks for any help or suggestions.
I understand that because Premiere is 64 bit, software will have to be redone. But I am still trying to determine if there is more than one product in the market. Usually there are a number of software companies providing software to do a specific task and I have only been able to find the one.
This is a software plug in suite from Boris FX: http://www.borisfx.com/after_effects/bccae/ Third bullet from the bottom under "Key Features for After Effects Users" is what should work for your needs. These plug ins also install in PPro, even though they only mention AE. I use it and will be upgrading when I finally migrate up to CS5. If you just want the motion stabilizer, I believe that is possible for a lower price. The trial version is fully functional for 14 days. Continuum Complete 7AE was just released and is 64-bit/CS5 compatible.
Below answer from Boris:
The Boris Continuum Optical Stabilizer Unit is currently not compatible with Premiere Pro CS5.
We hope to update the Optical Stabilizer Unit within the next few weeks.
However, the Optical Stabilizer Plug-in within the Boris Continuum Complete 7 is compatible with Premiere Pro CS5.
As I mentioned we will be making this Plug-in available as a "unit" with in the next few weeks.
ProDad Mecalli V2 Pro (Adobe listed as an approved plug-in) available as a trial download, works exceptionaly well in PP 5.5.2 used it for 5 months, but, you will need to render, but it is very fast and it will work on all versions going back to PP 1.5.1 as well as Premiere Elements 4>.
CS6.1 has the Warp Stabilizer included ,(previously in After Effects as an extra), but, have not used it
