chrisdornan
Flash Media Server for Red Hat EL 6
Jul 16, 2011 4:58 PM
I have tried installinf FMS 4.0.2 on RHEL/CentOS 6 with no luck.
The installer complains about missing libcap. When I supress the check the installer warns about installation on an unsupported O/S.
Unfortunately, I can't it to work on CentOS 5. The log says:
2011-07-17      00:39:40        23795   (i)2571011      Server starting...      -
2011-07-17      00:39:40        23795   (i)2581224      Edge (23818) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/fms/conf/Server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1".        -
2011-07-17      00:39:40        23795   (i)2571111      Server started (/opt/adobe/fms/conf/Server.xml).        -
2011-07-17      00:39:45        23795   (i)2581226      Edge (23818) is no longer active.       -
2011-07-17      00:39:45        23795   (w)2581255      Edge (23818) _defaultRoot__edge1 experienced 1 failure[s]!      -
Followed by many more edge failures.
Meanwhile the CentOS 5 installation works fine.
Does anyone have any idea what the problem could be or whether there is a workaround?
    Jul 18, 2011 12:55 AM   in reply to chrisdornan
    Datasheet does not state support for EL6, only 5.3. I am sure one of the support guys may be able to help further.
    Jul 18, 2011 5:59 AM   in reply to chrisdornan
    You are in the correct forum section to ask. I do not have time to test on EL6 today
    Jul 18, 2011 7:31 AM   in reply to chrisdornan
    I'am currently try the same things. I run FMS 4 in RHEL 6.
    after couple time installing the right package (libcap a.k.a. library package) I'am success installing FMS 4 with some comment:
    WARNING: Your Linux distribution, RedHat x86_64  is not supported by this
              installer.
    but I keep on going with readme instruction:
    13) To start the server manually, go to the installation directory (default is /opt/adobe/fms/). Use the command "./fmsmgr server fms start" to start Flash Media Server and "./fmsmgr adminserver start" to start Flash Media Administration Server.
    [root@localhost ~]# cd /opt/adobe/fms/
    [root@localhost fms]# ./fmsmgr server fms start
    Server:fms command:start
    ./server: command substitution: line 46: syntax error near unexpected token `elif'
    ./server: command substitution: line 46: ` elif [ -f /etc/mandrake-release ] ; then'
    sed: -e expression #1, char 6: unknown option to `s'
    sed: -e expression #1, char 9: unknown option to `s'
    sed: -e expression #1, char 14: unknown option to `s'
    ./server: line 41: /etc/SUSE-release: No such file or director
              installer.
    1024
    WARNING: FMS requires the maximum number of processes > 32K.
             Adjust ulimit to match system requirements.
    NPTL 2.12
    Starting Adobe Flash Media Server (please check /var/log/messages)
    [root@localhost fms]# ./fmsmgr adminserver start
    Admin server:fmsadmin command:start
    ./adminserver: command substitution: line 45: syntax error near unexpected token `elif'
    ./adminserver: command substitution: line 45: ` elif [ -f /etc/mandrake-release ] ; then'
    ./adminserver: line 40: /etc/SUSE-release: No such file or directory
              installer.
    Starting Adobe Flash Media Admin Server (please check /var/log/messages)
    I check in system monitor
    process name: fms admin and fmsmaster ; both status: sleeping.
    Q: 1. Does this mean FMS is running?
    Q: 2. is there FMS server adminstration console as in microsoft installation?
    The problems are: I can't connect adobe flash media live encoder 3.2, live application to the FMS
    FYI: I already try in Microsoft 2003 server R2. no problem at all, I can wacth live streaming fine in flv application.
    Sep 26, 2011 6:37 AM   in reply to chrisdornan
    I am running FMS 4.0 on RHEL 6.0 64bit.  It took some work but everything is working properly.  I knew I should have writtien down what I did at the time, but I will try to recall and pass along what I did.
    edit the installFMS script
    search for
    cd_check "Red Hat Enterprise Linux Client release 5" /etc/redhat-release redhat-RHEL5-i686
    add the following line right below it
    cd_check "Red Hat Enterprise Linux Client release 6" /etc/redhat-release redhat-RHEL6-i686
    execute the installFMS script.  You can let the installer start the service, but they will fail.
    Depending on your version of libcap, you will have to modify the libcap link in the /rootinstall/ (/opt/adobe/fms)
    I had to delete the link and replace it with a symbolic link libcap.so.1 -> /lib64/libcap.so.2
    If memory serves me there is one more file you have to modify, in the /rootinstall/ edit the server file
    again search for
    and add
    Hope that helps.
    Sep 26, 2011 7:14 AM   in reply to r.cira
    dully noted thanks for reporting the answer. People like when i mark stuff as correct so that it attributes so to speak  into adobe database special probably helps other people find answers so could u mark yourself as giving the correct answer please.
    Sep 27, 2011 8:08 AM   in reply to chrisdornan
    Hi everyone,
    As of now , i do not know of any movement to RHEL 6, but if RHEL is itself moving to that distro , I guess we too follow them. I will update as soon as there is some information to share. Thanks for bringing this up.
    For now, we do not have support for RHEL 6, good to know of the above workaround
    Sep 29, 2011 1:58 PM   in reply to chrisdornan
    According to  https://access.redhat.com/support/policy/updates/errata/    RHEL5 / CentOS 5 are supported until March 31, 2014https://access.redhat.com/support/policy/updates/errata/ .
    Not sure where you got the EoL in Q4 2011.
    Oct 5, 2011 12:41 PM   in reply to r.cira
    I just successfully used r.circa's solution to install FMS 4.5 on RHEL6 x64. All is working well. Thanks.
    Oct 12, 2012 11:00 PM   in reply to r.cira
    I config same, but show :
              installer.
    I's sever Centos 6 x86_x64
    Pls help
    Dec 6, 2012 11:11 AM   in reply to Zone.Media.Coporation
    Thanks again to "r.circa" who came up with the original solution. Here are some updated instructions that don't require creating a symbolic link to fix the libcap issue.
    I was able to get 4.5.4 working on RHEL 6.3. Here's what to do:
    Update to latest errata with 'yum update'; reboot
    Also make sure you have latest version of both libcap and compat-libcap1 packages (via yum update...)
    Exract the latest FMS install archive (4.5.4 as of this writing).
    In that folder, for a successful, error-free install you need to edit three files:
    server
    adminserver
    installFMS
    For 'server' and 'adminserver', edit these sections as follows:
      # Red Hat Linux
      if [ -f /etc/redhat-release ]; then
            cd_check "Red Hat Enterprise Linux [WAE]S release 3" /etc/redhat-release redhat-RHEL3-i686
            cd_check "Red Hat Enterprise Linux [WAE]S release 4" /etc/redhat-release redhat-RHEL4-i686
            cd_check "Red Hat Enterprise Linux Server release 5" /etc/redhat-release redhat-RHEL5-i686
            cd_check "CentOS release 4" /etc/redhat-release centos-4-i686
            cd_check "CentOS release 5" /etc/redhat-release centos-5-i686
            DIST='RedHat'
            PSUEDONAME=`cat /etc/redhat-release | sed s/.*\(// | sed s/\)//`
            REV=`cat /etc/redhat-release | sed s/.*release\ // | sed s/\ .*//`
        DIST="${DIST} ${REV} ${PSUEDONAME}"
            cd_result $DIST
    ..and:
    # check distribution
    PLATFORM="Linux"
    ARCH=`uname -m`
    SUPPORT=0
    DISTRO=`check_distro`
    case $DISTRO in
        redhat-RHEL5-i686)
        redhat-RHEL6-i686)
        centos-5-i686)
        Debian)
    Similarly, for installFMS edit these sections as follows:
      # Red Hat Linux
      cd_check "Red Hat Enterprise Linux Server release 6" /etc/redhat-release redhat-RHEL6-i686
      DIST='RedHat'
      cd_result $DIST
    and...
    PLATFORM="Linux"
    case $DISTRO in
        redhat-RHEL5-i686)
        redhat-RHEL6-i686)
        centos-5-i686)
            Debian)
    run installFMS as normal and it should just work.
    I hope that helps. I also hope Adobe starts to support RHEL 6 users. Seriously, how much effort would it take?
    Best,
    Daniel
