Can anybody tell me if there is a way to resize a graph non-uniformly and still have the category and value text labels scale correctly?
For instance if I want to scale the graph to be twice as wide, the text inside will be distorted.
thanks
/Ludde
It's the default shortcut for the Uniform Text command (see Edit > Keyboard Shortcuts > Other Text). It has been availabe for more than one decade.
To test, just create a graph, scale it horizotally, leave it selected and hit the shortcut. You could also take a normal text object, stretch it and then hit the shortcut.
steve fairbairn wrote:
It's a bad solution though, especially for graphs. If you scale the graph you will also scale the type.
Cmd+Shift+X only normalizes the type to 100% vertical and horizontal.
This means that it will usually be either too big or too small after scaling, despite the Cmd+Shift+X.
I wouldn't say it's a bad solution, but agreeably it's not perfect.
The best solution would be to be able to select whether type in graphs should scale uniformly, non-uniformly or not at all.
//Ludde
Excellent thinking! Often graphs are done in a series, for annual reports and that sort of thing; so it's necessary to use a standard type size in all of them.
Non-scaling type would be a brilliant idea.
You might like to make a feature request of the idea. :-)
