FLASH CS5.5 Fails to launch on Mac OS 10.6.8
Sep 27, 2011 11:49 AM
Tags: #error #launch #mac_os_10.6.8 #flash_cs5
Hi.  Have seen some similar posts, but not helped.  Running on brand new iMacs all with same image, some work, some don't.  The following is what I copied from the amt3.log file in the /tmp folder.  Any ideas?
2011-09-27 09:54:27 [200]  AMT: START SESSION, library version 4.0.0.21,4.0
2011-09-27 09:54:27 [200]  AMT: Initializing /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app
2011-09-27 09:54:27 [200]  AMT: Adobe License Manager version 3.5 (build 2.0) RELEASE
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/adobe_ caps.framework/adobe_caps
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/adobe_ca ps.framework/adobe_caps
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
2011-09-27 09:54:27 [200]  ServiceLoader: Found library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_c aps
2011-09-27 09:54:27 [200]  PCDService: PCD Service in threaded mode
2011-09-27 09:54:27 [200]  performance: AMTPreObtainProductLicense took 84.834000 ms
2011-09-27 09:54:27 [200]  PCD thread: PCD thread started
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/Adobe_ OOBE_Launcher.framework/Adobe_OOBE_Launcher
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/Adobe_OO BE_Launcher.framework/Adobe_OOBE_Launcher
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/Adobe_OOBE_Launcher.framework/Adobe_OOB E_Launcher
2011-09-27 09:54:27 [200]  ServiceLoader: Found library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/ A/adobe_oobe_launcher
2011-09-27 09:54:27 [200]  AMT: App Product Locale [0] = en_GB
2011-09-27 09:54:27 [200]  AMT: App Product Locale [1] = en_US
2011-09-27 09:54:27 [200]  AMT: App Product Locale [2] = en_XM
2011-09-27 09:54:27 [200]  AMT: App Product Locale [3] = nb_NO
2011-09-27 09:54:27 [200]  AMT: App Product Locale [4] = da_DK
2011-09-27 09:54:27 [200]  AMT: App Product Locale [5] = fi_FI
2011-09-27 09:54:27 [200]  AMT: App Product Locale [6] = ko_KR
2011-09-27 09:54:27 [200]  AMT: App Product Locale [7] = ar_AE
2011-09-27 09:54:27 [200]  AMT: App Product Locale [8] = el_GR
2011-09-27 09:54:27 [200]  AMT: App Product Locale [9] = he_IL
2011-09-27 09:54:27 [200]  AMT: App Product Locale [10] = hu_HU
2011-09-27 09:54:27 [200]  AMT: App Product Locale [11] = ro_RO
2011-09-27 09:54:27 [200]  AMT: App Product Locale [12] = uk_UA
2011-09-27 09:54:27 [200]  config: Loading configuration for /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Resources/AMT/application.xml
2011-09-27 09:54:27 [200]  config: Found payload code {D97AF04B-B70A-4862-BC25-31E6D9C4A529}
2011-09-27 09:54:27 [200]  PCDService: found driver code {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:27 [200]  config: config: Host app was installed, using installed license configuration.
2011-09-27 09:54:27 [200]  PCDService: No value for key [FLMap] in hive [FlashPro-CS5.5-Mac-GM{|}ALL] in cache.
2011-09-27 09:54:27 [200]  config: Setting current license to the driver at startup because no mapping was found.
2011-09-27 09:54:27 [200]  config: Setting current license to WebSuitePremium-CS5.5-Mac-GM [ALL]
2011-09-27 09:54:27 [200]  config: payload code: {D97AF04B-B70A-4862-BC25-31E6D9C4A529}
2011-09-27 09:54:27 [200]  config: driver payload code: {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:27 [200]  config: driver licensing code: WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:27 [200]  config: current licensing code: WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:27 [200]  config: current locale code: ALL
2011-09-27 09:54:27 [200]  config: Done loading configuration
2011-09-27 09:54:27 [200]  AMT: Locale from PCD [0] = en_US
2011-09-27 09:54:27 [200]  AMT: Reordered Installed App Product Locale [0] = en_US
2011-09-27 09:54:27 [200]  config: Setting insalled locales
2011-09-27 09:54:27 [200]  config: Changing locale to "en_US" because old locale "" is not in the new list of installed languages
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/asneu. framework/asneu
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/asneu.fr amework/asneu
2011-09-27 09:54:27 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/asneu.framework/asneu
2011-09-27 09:54:27 [200]  ServiceLoader: Found library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
2011-09-27 09:54:27 [200]  PCDService: No value for key [ReLaunchMode] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [ReLaunchMode] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:27 [200]  AMT: App's last known config file is: /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Resources/AMT/application.xml
2011-09-27 09:54:27 [200]  apf: current config file path is: /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Resources/AMT/application.xml
2011-09-27 09:54:27 [200]  AMT: config: Finding license info for payload: {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:27 [200]  AMT: config: PayloadCode: {D97AF04B-B70A-4862-BC25-31E6D9C4A529}
2011-09-27 09:54:27 [200]  AMT: config: Driver PayloadCode: {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:27 [200]  AMT: config: Installed LicensingCode: WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:27 [200]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [BridgeTalkCode] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [FlashPro-CS5.5-Mac-GM] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [EULA] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Registration] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Registration] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Growl] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Growl] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Updates] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [Updates] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:27 [200]  AMT: Application can be serialized (sif file found).
2011-09-27 09:54:27 [200]  config: Setting current license to WebSuitePremium-CS5.5-Mac-GM [en_US]
2011-09-27 09:54:27 [200]  PCDService: No value for key [AMTConfigPath] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in cache.
2011-09-27 09:54:27 [200]  PCDService: No value for key [ExpirationDate] in hive [FlashPro-CS5.5-Mac-GM] in master.
2011-09-27 09:54:27 [200]  AMT: Subsequent launch (serial [95489146347624289456]).
2011-09-27 09:54:27 [200]  AMT: Application state initialized.  Obtaining Product License.
2011-09-27 09:54:27 [200]  AMT: Obtaining client features from cache.
2011-09-27 09:54:27 [200]  AMT: Obtaining client product info from cache.
2011-09-27 09:54:27 [200]  AMT: Running in PROV_APP
2011-09-27 09:54:27 [200]  PCDService: No value for key [EULADelay] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  PCDService: No value for key [MediaTag] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:27 [200]  config: No media tag found for payload {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:27 [200]  config: Using default media policy RET
2011-09-27 09:54:27 [200]  uiswitch: EULA has already been accepted.
2011-09-27 09:54:27 [200]  AMT: This is a subsequent launch. Deferring services.
2011-09-27 09:54:27 [200]  performance: AMTObtainProductLicense took 277.531006 ms
2011-09-27 09:54:29 [200]  AMT: Pre-Validating Product License.
2011-09-27 09:54:29 [200]  AMT: Services not yet loaded in this session.
2011-09-27 09:54:29 [200]  AMT: Loading services in background to get ready for Validate call.
2011-09-27 09:54:29 [200]  AMT: Spawning background thread to load services.
2011-09-27 09:54:29 [200]  performance: AMTPreValidateProductLicense took 0.057000 ms
2011-09-27 09:54:29 [200]  AMT: Starting work on prevalidate thread.
2011-09-27 09:54:29 [200]  AMT: AMT: PreValidating Product License.
2011-09-27 09:54:29 [200]  AMT: Launch Workflow not yet done in this session.
2011-09-27 09:54:29 [200]  AMT: Starting Background Subsequent Launch Workflow
2011-09-27 09:54:29 [200]  AMT: Starting ALM workflow.
2011-09-27 09:54:29 [200]  AMT: Initializing ALM for serialized activation.
2011-09-27 09:54:29 [200]  ALMService: Initializing as licensed app
2011-09-27 09:54:29 [200]  ALM: _info_: Start ALM 3.5 Release (build 3.5.2.0)
2011-09-27 09:54:29 [200]  SLCoreService: Starting up SLCore 1.7 Release (build 1.7.26.242757).
2011-09-27 09:54:29 [200]  SLCoreService: Service construction took 0.0 ms and succeed.
2011-09-27 09:54:29 [200]  ALM: _info_: LEID passed WebSuitePremium-CS5.5-Mac-GM is used to configure SLCore = 0
2011-09-27 09:54:29 [200]  ALM: _info_: Host app is Licensable App
2011-09-27 09:54:29 [200]  PCDService: No value for key [FlashPro-CS5.5-Mac-GM{|}5] in hive [SSC-CS5.5-LE-Dominance] in master.
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID FlashPro-CS5.5-Mac-GM with AMT Path /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Resources/AMT
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID WebSuitePremium-CS5.5-Mac-GM with AMT Path /Library/Application Support/Adobe/Adobe Creative Suite 5.5 Web Premium/AMT
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID DesignSuitePremium-CS5.5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID VideoSuitePremium-CS5.5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/VideoSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID MasterCollection-CS5.5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/MasterCollection-CS5.5-Mac-GM
2011-09-27 09:54:29 [200]  ALM: _info_: Found LEID ELearningSuite-ES2.5-Mac-GM with AMT Path /Library/Application Support/Adobe/ssc/ELearningSuite-ES2.5-Mac-GM
2011-09-27 09:54:29 [200]  PCDService: No value for key [MediaTag] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:29 [200]  config: No media tag found for payload {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:29 [200]  config: Using default media policy RET
2011-09-27 09:54:29 [200]  ALM: _info_: MediaTagPolicy is RET
2011-09-27 09:54:29 [200]  PCDService: No value for key [NTL_WO_SN] in hive [WebSuitePremium-CS5.5-Mac-GM] in master.
2011-09-27 09:54:29 [200]  ALM: _info_: Canonical LEID is FlashPro-CS5.5-Mac-GM
2011-09-27 09:54:29 [200]  ALM: _info_: Driver LEID is WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:29 [200]  PCDService: No value for key [954897075440984411885632] in hive [RejectedSNDomain_CS5] in cache.
2011-09-27 09:54:29 [200]  SLCoreService: Reading product config [/Library/Application Support/Adobe/Adobe Creative Suite 5.5 Web Premium/AMT/SLConfig.xml]
2011-09-27 09:54:30 [200]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
2011-09-27 09:54:30 [200]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
2011-09-27 09:54:30 [200]  ALM: _info_: Set Running Locale to en_US
2011-09-27 09:54:30 [200]  ALM: _time_: (func: ALM_Initialize, duration: 0.150 sec)
2011-09-27 09:54:30 [200]  AMT: Performing ALM silent license verification.
2011-09-27 09:54:30 [200]  PCDService: No value for key [EncryptedSerial] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in cache.
2011-09-27 09:54:30 [200]  PCDService: No value for key [Serial] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in cache.
2011-09-27 09:54:30 [200]  config: No pre-serial number found in {B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}
2011-09-27 09:54:30 [200]  PCDService: No value for key [PSN] in hive [WebSuitePremium-CS5.5-Mac-GM{|}en_US] in cache.
2011-09-27 09:54:30 [200]  config: No en_US provisional serial number found in WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:30 [200]  PCDService: No value for key [PSN] in hive [WebSuitePremium-CS5.5-Mac-GM{|}ALL] in cache.
2011-09-27 09:54:30 [200]  config: No ALL provisional serial number found in WebSuitePremium-CS5.5-Mac-GM
2011-09-27 09:54:30 [200]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_US
2011-09-27 09:54:30 [200]  ALM: _info_: Searching license for locale en_US ...
2011-09-27 09:54:30 [200]  PCDService: No value for key [954891463476242894568057] in hive [RejectedSNDomain_CS5] in cache.
2011-09-27 09:54:30 [200]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_US
2011-09-27 09:54:30 [200]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
2011-09-27 09:54:30 [200]  ALM: _info_: Found existing serialization under LEID WebSuitePremium-CS5.5-Mac-GM, the serial number locale is en_US
2011-09-27 09:54:30 [200]  ALM: _info_: This is the running locale, stop the search
2011-09-27 09:54:30 [200]  config: Setting current license to WebSuitePremium-CS5.5-Mac-GM [en_US]
2011-09-27 09:54:30 [200]  SLCoreService: Syncing to license store...
2011-09-27 09:54:30 [200]  SLCoreService: Found server mkey.
2011-09-27 09:54:30 [200]  SLCoreService: Found 1 license file(s)
2011-09-27 09:54:30 [200]  SLCoreService: Parsing license file [77238781.lic] succeed.
2011-09-27 09:54:30 [200]  SLCoreService: License store synchronization took 85.1 ms and succeed.
2011-09-27 09:54:30 [200]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
2011-09-27 09:54:30 [200]  PCDService: No value for key [PDApp_WF] in hive [WebSuitePremium-CS5.5-Mac-GM] in cache.
2011-09-27 09:54:30 [200]  ALM: _info_: Performing Disabled Check
2011-09-27 09:54:30 [200]  SLCoreService: Feature ALM_CS5_5WebPremiumGM_5.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Acrobat_10.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Acrobat_Base_10.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Acrobat_Distiller_10.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Acrobat_Professional_10.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Bridge_ColorSettings_4.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Contribute_6.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Contribute_Base_6.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature CreativeSuite_5.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature CreativeSuite_WebPremium_5.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Dreamweaver_11.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Dreamweaver_Base_11.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Fireworks_11.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Fireworks_Base_11.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature FlashBuilder_4.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature FlashBuilder_Base_4.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature FlashBuilder_Prem_4.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature FlashCatalyst_1.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature FlashCatalyst_Base_1.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Flash_11.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Flash_Base_11.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Flash_Pro_11.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Illustrator_15.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Illustrator_Base_15.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature MediaEncoder_Base_2.5 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Photoshop_12.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
2011-09-27 09:54:30 [200]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
2011-09-27 09:54:30 [200]  ALM: _info_: Event Value = 195208704
2011-09-27 09:54:30 [200]  ALM: _info_: No need to launch SA
2011-09-27 09:54:30 [200]  PCDService: No value for key [ALM_Info_S1] in hive [WebSuitePremium-CS5.5-Mac-GM{|}en_US] in cache.
2011-09-27 09:54:30 [200]  PCDService: No value for key [ADOBEID] in hive [954891463476242894568057] in cache.
2011-09-27 09:54:30 [200]  ALM: _info_: Performing Block Check
2011-09-27 09:54:30 [200]  ALM: _info_: Block Check ByPassed
2011-09-27 09:54:30 [200]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.117 sec)
2011-09-27 09:54:30 [200]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
2011-09-27 09:54:30 [200]  AMT: License check shows serialized product is already activated.
2011-09-27 09:54:30 [200]  ALM: _info_: Entered ALM_NeedANAG
2011-09-27 09:54:30 [200]  PCDService: No value for key [ClaimStatus] in hive [954891463476242894568057] in cache.
2011-09-27 09:54:30 [200]  ALM: _info_: Exiting ALM_NeedANAG
2011-09-27 09:54:30 [200]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:30 [200]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:30 [200]  PCDService: No value for key [Updates] in hive [{B52B6AB6-092E-4E4D-AB8A-8D69CBAF1673}] in master.
2011-09-27 09:54:30 [200]  PCDService: No value for key [Updates] in hive [{D97AF04B-B70A-4862-BC25-31E6D9C4A529}] in master.
2011-09-27 09:54:30 [200]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
2011-09-27 09:54:30 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/Update rNotifications.framework/UpdaterNotifications
2011-09-27 09:54:30 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/UpdaterN otifications.framework/UpdaterNotifications
2011-09-27 09:54:30 [200]  ServiceLoader: looking for library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/UpdaterN otifications
2011-09-27 09:54:30 [200]  ServiceLoader: Found library /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions /A/UpdaterNotifications
2011-09-27 09:54:30 [200]  AUMService: IsUpdaterEnabled call
    May 4, 2012 12:16 AM   in reply to Avron
    Hallo Avron! I have the same problem. Flash will not starting. How are you solve this problem? Can you explain me the fix exactly, please? Which network accounts, redirections and script mean you? Thanks.
