Hi guys,
I've finished developing my app, live video streaming for iOS, I submitted on apps store but they rejected! (I didn't read the guideline carefully T_T https://developer.apple.com/appstore/resources/approval/guidelines.html)
Is there a way to get through? Much appriciate! Thanks!!
Thanks for sharing this information. Are you supporting any other mobile platform. Have you mentioned the name anywhere in description or in your app? You could remove those.
You should be able to achieve HTTP LIve streaming with AIR 3, using the stageVideo feature. For the time being, you could enforce use of wi-fi for your application. In the application xml, add the following :
<key>UIRequiresPersistentWiFi</key>
<string>YES</string>
Sanika
Hi Sanika,
Thanks for your reply! Im not using Flash builder but Flash CS5.5 and AIR 3 RC, there is application.xml, and after building, the ipa file has this xml in META-INF/AIR/application.xml. i´ve tried to take the xml out of the air folder or rename the folder, then in the Resource file, i changed the corresponding path. But the ipa no more works, I think the application (the most heavy file in the ipa) is also pointing to the xml, but I don´nt know how to change it to point the new path.
Any idea? Im trying to remove any word like 'AIR' that appears in the info files.
Thanks a lot!
Hi Stephen,
application.xml is required for the application to work. You shouldn't temper with it. I am not sure if the app got rejected because of mentioning "AIR" as there are many AIR applications present on AppStore. Have you mentioned the name of other mobile platforms that your app supports - android, Blackberry playbook etc somewhere in the description or in your application? I hope you will be able to get around the second clause with UIRequiresPersistentWiFi.
Sanika
Hi Sanika,
The first issue (3.1) i've solved already, you're right, it was the app description. Thanks man!
But the second one I put wifi persistent key, but it only show warning when i'm using flight mode (on iphone). I also try to used NetworkInterface to detect wifi, but that's not supported on mobile 😞 is there another solution that I can enforce user to use wifi connection?
Many thanks!
Putiing UIRequiresPersistent Wi-fi should show you the dialog to select an available wi-fi, if present. Now that AIR 3 is releases, you should explore the stageVideo feature for streaming. See http://www.adobe.com/devnet/flashplayer/articles/stage_video.html. Also, with AIR 3, you can use native extensions to find the network information, you don't even need to write the extension yourself , it is available at http://www.adobe.com/devnet/air/native-extensions-for-air/extensions/networkinfo.html.
Hope this helps.
Reagrds,
Sanika
Hi Sanika,
My app plays existing streams which servers are rtmp, and I can't change it to http streams. So even if I use stageVideo, it is still rtmp. That way won't pass the rule 9.4, right? (correct me if I'm wrong!)
For now I'm gonna try the NetworkInfo extension to enforce Wifi connection.
Thanks for your help!
I'm not sure, but rtmp isn't support by ios devices. You have to use HLS.
If you'r using FMS, take a look at http://www.adobe.com/devnet/flashmediaserver/articles/introducing-fms45.html
BR
